03-12-2010, 07:52 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | 2630 version 57.20 with mx key using easy cable Version: SIMLOCK SERVER Provider: Vodafone, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341500000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23415F PhoneType:RM-298 SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia MCU file: rm298__57.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005DD901:3B8ADA60 Area [01000000-0101FFFF] erased in 0.375 s Area [016C0000-016DFFFF] erased in 0.359 s Area [013E0000-013FFFFF] erased in 0.359 s Area [01480000-0149FFFF] erased in 0.375 s Area [01C20000-01C3FFFF] erased in 0.359 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 9.563 s Reading Simlock info ... Imei net: 35521903201673 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN to unlock any mobile which support easy cable here is trick how to use firstly power on ur handset without sim card and then insert easy cable and then scan ur handset this come ur handset local mode then do ur opreation plz press thanx button if u like my advice |
2630 version 57.20 successfull unlocked | mianjabbar | Universalbox | 0 | 02-15-2010 11:26 |
2630 version 57.20 it is possible to unlock with mx key | neeraj1st | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-11-2010 12:26 |
