04-02-2010, 13:50 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | 2680s auto off after fully ON i have flashed the set completely but same problem remains Code: Version Info: MCU SW version: V 05.28 05-11-08 RM-392 (c) Nokia HW version: 2001 UEM version: 4386 UPP version: 12642 RFIC version: 0500 DSP version: ICPR72_08w32_UPP LCD version: SEIKO PPM version: V 05.28 05-11-08 RM-392 (c) Nokia MR BT MCM version: 2222-143C Content Pack version: Content: mr V 05.28 05-11-08 RM-392 (c) Nokia Product Info: Production serial number: IDN627073 Product code: 0564367 Module code: 0203726 Basic production code: 0556744 Long production SN: 0 Serial Numbers: IMEI plain: 356390023220374 IMEI spare to net: 3A 65 93 00 32 22 30 07 IMEI SV to net: 33 65 93 00 32 22 30 27 F4 Other Info: Model : Nokia 2680s-2 (Connect Contemporary) CS type : GSM/DCS1800 BSI: 4.4 KOhm Imei net: 35639002322037 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
04-02-2010, 16:42 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | first format with jaf (file system)if not work then Check it with charger if it working with charger then replace charging jack,if not solved then problem in uem. |
04-05-2010, 13:06 | #14 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | Jumper solution is not 100% working, at first you will get battery life max 24 hours. To fix this issue only way is to change UPP. That would be 100% fix. B.R. Alkapone |
nokia 2680s trips off after booting completely | tonywireless | Nokia Base Band 5 ( BB-5 ) | 6 | 02-18-2010 05:51 |
2680-s off after 3 min | antbly | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-17-2009 14:03 |
2100 Auto off after 4 or 5 hours | Aamir_Zia | Nokia Hardware & Hardware Repair | 4 | 08-04-2008 19:48 |
nokia 7610 auto off after light off | mobiletomobile | Nokia Hardware & Hardware Repair | 3 | 12-10-2007 18:01 |
c55 auto off after wrong software repair | bengong | E-Gold Based Phones | 2 | 06-25-2003 21:47 |
