Old 03-19-2010, 20:09   #1 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
2680s version 56.17 unlock problem
Imei net: 35523703217415
Version: SIMLOCK SERVER
Provider: Virgin, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343000000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.LOCKED (MCC+MNC): 23430F
PhoneType:RM-392
SwVersion: V 56.17 24-03-09 RM-392 (c) Nokia
MCU file: rm392__56.17.mcusw
Trying to find patch position ...OK
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720
Performing Flash Authentication ...OK
UEM ID: 005FA63A:3B8ADA60
Area [01000000-0101FFFF] erased in 1.202 s
Area [01220000-0123FFFF] erased in 1.150 s
Area [01440000-0145FFFF] erased in 1.168 s
Area [014C0000-014DFFFF] erased in 1.167 s
Area [01CE0000-01CFFFFF] erased in 1.178 s
Programming ...
Programming completed.
Phone not responding !
PLS HELP ME TO UNLOCK THIS PHONE..BR
Old 03-19-2010, 20:15   #2 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
Counter: 0/3, 0/10
PhoneType:RM-392
Programming ...
It often happens with DCT4 phones, if you are using easy cable then use F-Bus, if already using F-bus check your cable quality it may not be connecting properly.
Old 03-19-2010, 20:15   #3 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
chick it MCU file: rm392__56.17.mcusw
i know rm392__06.17.mcusw
Old 03-19-2010, 20:20   #4 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
This is mcu file is valid bro, new phones are coming with this mcu and changed security.
@damabib
Other thing you can do is flash it with 6.17 or lower version and then try to unlock.\
Old 03-20-2010, 12:53   #5 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Originally Posted by adnann5 View Post
this is mcu file is valid bro, new phones are coming with this mcu and changed security.
@damabib
other thing you can do is flash it with 6.17 or lower version and then try to unlock.\
br
i downgrade it only white screen this version is not surported unlocked???br
Old 03-20-2010, 13:10   #6 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
it often happens with dct4 phones, if you are using easy cable then use f-bus, if already using f-bus check your cable quality it may not be connecting properly.
i use 4 different cable same....br
Old 03-20-2010, 13:10   #7 (permalink)
Member: 782416
Sonork: ****
Thanks Meter: 81
hi,
i think it's not supported in mx-key for unlocking
Old 03-23-2010, 19:54   #8 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Originally Posted by REDZTER View Post
hi,
when mx key will support unlock this phone???br
Old 03-23-2010, 19:58   #9 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro, are u update mxky mobileEx 3.3 (rev1.7_fixed)
Old 03-25-2010, 11:40   #10 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
yes am using latest updates....i need a responce from mx key team ..if supported or not br
Old 03-27-2010, 17:19   #11 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
No responce from mx key surpoter yet???humn strange
Old 03-27-2010, 18:02   #12 (permalink)
Member: 888048
Sonork: 123
Thanks Meter: 30
Mx-key not support but HWK support ATM. try unlock with HWK
Old 03-28-2010, 05:49   #13 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
version 56.xx
this is sl-3 security and currently not supported
wait for update
Old 03-28-2010, 06:37   #14 (permalink)
Member: 888048
Sonork: 123
Thanks Meter: 30
Originally Posted by cel_phon View Post
version 56.xx
wait for update
Its not SL3, its unlock done by HWK.
Before unlock:
MCU SW : V 56.17 24-03-09 RM-392 (c) Nokia
PPM SW : V 06.17 10-03-09 RM-392 (c) Nokia EA
Prd.Code: 0582721
Bpr.Code: 0578421
Prod.Sn : DRN772333
HW Vers : 1200
UEM : 4386
UPP : 12648 [3168]
RFIC Ver: 0500
DSP Vers: ICPR72_08w52_UPP
LCD Type: SEIKO
CAM Prim: GR0103D1012601022C00_001004
IMEI : 353194-03-615542-6
SL Conf : 234-33-00000000000
SL Prof : 800000000003000-B
SL Var : 00553531940361554200
SL Aux : 000B5555
HW Sig : B2E0BAE134BE74AF
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: CLOS
BLK2= L1: CLOS
Provider: Orange;United Kingdom
Unlock:
IMEI: 353194-03-615542-6, ASIC: 11
FILE: rm392__56.17.mcusw
1st Boot: Ok, DCT4, UPP: 3168 [Rm-392] [2.1.0.0]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x02FFFFFF,0020883C,St M58LR256HU
Algorithm: u3_intel.fia, Ver: 4.80.0
Algorithm Ok, MSID: 84428CAB7F12408490B6B9775C
Decoded MSID: 2C40BAE9-00DB133D-AA000000
Encoded FAID: 65A7438F-58EB90F1-13891924
Area1: 0x01000000-0x0101FFFF Erased, Time: 00:01
Area2: 0x01220000-0x0123FFFF Erased, Time: 00:01
Area3: 0x01440000-0x0145FFFF Erased, Time: 00:01
Area4: 0x01CE0000-0x01CFFFFF Erased, Time: 00:01
PAT Flashing Completed, Time: 00:02
SimLocks Initialized (Patch Ok), Time: 00:00
SimLocks Initialized, Time: 00:28
Info:
Product : Nokia 2680s
Prd.Code: 0582721
Bpr.Code: 0578421
Prod.Sn : DRN772333
HW Vers : 1200
UEM : 4386
UPP : 12648 [3168]
RFIC Ver: 0500
LCD Type: SEIKO
SL Conf : 001-01-00000000000
SL Aux : 000B5555
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Old 03-28-2010, 06:42   #15 (permalink)
cdma_sollution's Avatar
Member: 1271517
Sonork: 100.1606968
Thanks Meter: 54
yes bro it is unlocked whith hwk i will done last yesterday
Nokia 2680s version 56.17 flashfile needed damabib MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-18-2010 19:22
Nokia 2680 version 56.17 unlocking DONE !!! pastorsam Universalbox 13 09-17-2009 10:13
Nokia 2680 version 56.17 unlocking problem pastorsam Universalbox 0 09-14-2009 15:13
nokia 2680s version 56.17 unlocking sesime Universalbox 1 07-18-2009 22:39
Page generated in 0.27345 seconds with 9 queries
