Old 05-24-2011, 06:09   #1 (permalink)
yahoo.mobiles's Avatar
Member: 1196372
Thanks Meter: 16
Red face wat is error ??/? (ANSWERED)
Version from phone: 07.23
Version from file: 07.23
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 4] - C0804A8F
Using device: HTI BOX, FW ver: 00.08
Driver: HTIBUS, ver: 3.4.7.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Reading Important data ...
Reading RPL backup ...
Reading Phone ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 52.99 KB
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
Sending Overflow Loader(0x2E4 bytes) ...
Overflow loader running ..
Sending CustomLoader ...OK
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1F500016628E8C568DB3BCCFCAD0285E90FE8E3B
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
TransmissionMode: DDR&TX2
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Flash Imei: 35693003621627
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35693003621627_BA CK.rpl"
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: rm436__07.23.mcusw
[BB5,BB5 ALGORITHM] size: 18.06 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 19.12 MB
CMT NOR area [00000000-000006BF]
erased in 1 min 32.860 s
Flash programming ...
Error chk C7012D0103CD
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00040000, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: C7 01 2D 01 03 CD 00
ANY HANDSET WRITE FLASH DIS ERROR SHOWING MX BOX
HOW CAN SALOVED ERRORR
IAM USING IPMART CABLE
DIS BOX WORST
Old 05-24-2011, 06:54   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
DIS BOX WORST
how come you be so sure?
check your cable, you're over confidence to use that cable BRAND.
Old 05-24-2011, 07:26   #3 (permalink)
Member: 1196372
Thanks Meter: 16
U tell me best cable????
Old 05-24-2011, 07:55   #4 (permalink)
Member: 197541
Thanks Meter: 28
try flash using USB cable...
Old 05-24-2011, 08:09   #5 (permalink)
Member: 1196372
Thanks Meter: 16
alll time usb flashinmg ?????
why insert rj 45 pin????
mx-box is a ice ***** lalepop
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.17972 seconds with 9 queries
