11-16-2012, 08:49 | #1 (permalink) |
Major Poster Join Date: Nov 2010 Location: AP
Member: 1436625 Status: Offline Thanks Meter: 2 | 2690_Failed to read SP data SW version: V 10.65 09-12-10 RM-635 (c) Nokia Imei plain: 35486004751402-0 Product code: 059C947 Battery voltage: 4825 mV, current: 96 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST passed Failed to read SP data |
The Following User Says Thank You to ram4u For This Useful Post: |
11-16-2012, 14:36 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
It's Hardware Problem Means Camera Problem Remove Camera Than Buscheck Post Result Here.. BR. Arsalan gsm2000. | |
11-16-2012, 14:47 | #4 (permalink) | ||
No Life Poster Join Date: Jul 2009 Location: JHELUM,PAKISTAN
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Quote:
There is also a line in log that SIM LOCK INVALID So it's seems to be that sp data is corrupted. | ||
11-16-2012, 20:22 | #5 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Try to Flash with Latest Firmware, Write Simlock Backup if available, No other option then Factory RPL. BR, ZUBER | |
