09-01-2012, 12:18 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | 2700c-2 cam prob try resolve with dcc from server but same prob please help & upload appropriate dcc file log below MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C085CB22 Using device: USB ROM and HTI, FW ver: 00.50, SN: 010007E1 Connection status: OHCI:HUB::USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: rm561__09.97.mcusw [BB5,BB5 ALGORITHM] size: 19.41 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1CD0010829C549504F12EA72A4F7C09AFFAE3EBA CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2223E7A2 Verifying communication to device OK. Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.688 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.656 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 3.891 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.453 s CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 43.813 s CMT FLASH,NOR area [01380000-0151FFFF] erased in 9.969 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 28.157 s Processing PPM file: rm561__09.97.ppm_mena_a [BB5,BB5 ALGORITHM] size: 5.46 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 49.031 s Flash programming ... Programming completed in 27.265 s Processing CNT file: rm561__09.97.image_mena_a_blac [BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 27.735 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 4 min 3.250 s Flash programming ... Programming completed in 1 min 4.453 s Processing MMC file: rm561__09.97_sd_mea.fpsimage [BB5,BB5 ALGORITHM] version: 0.0.0 size: 96.54 MB Supported Ids: 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 No Erase header defined, erase will be skipped Erase skipped. Flash programming ... Programming completed in 1 min 15.813 s Total time for flashing process(boot+erase+write) was 12 min 9.562 s Waiting for USB device removal ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. Phone type: RM-561 (Nokia 2700 classic) SW version: V 09.97 18-06-10 RM-561 (c) Nokia Imei plain: 35201904148567-7 Product code: 0587992 Battery voltage: 3891 mV, current: 108 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF00000000, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352019041485677 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
09-01-2012, 15:49 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Your Problem for Camera is in Hardware. Check Camera Connector Physical Damage & it's contacts with Camera. Check Camera ways from connector to below components, at the last Check or change Camera will solve it. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
