08-03-2010, 07:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 1661 field to flashing cnt contain fact SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 843C 2208 0000 0040 C201 4000 00A2 6510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06A3BDA66 ASIC type: 11 UEM Imei: 35936403906885 Processing file: rh122_004.300 as MCU [DCT4,DCT4 ALGORITHM] size: 2.38 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 843C 2208 0000 0040 C201 4000 00A2 6510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06:2984DA60 Area [01000000-0100FFFF] erased in 0.844 s Area [01010000-0179FFFF] erased in 57.265 s Area [017A0000-017EFFFF] erased in 1.860 s Area [01F00000-01FDFFFF] erased in 0.484 s Flash programming ... Programming completed in 19.360 s File Processed in 1 min 28.344 s Processing file: rh1220_nai04.30aa as CNT [DCT4,DCT4 ALGORITHM] size: 175.35 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06:2984DA60 Area [01750000-0178FFFF] erased in 3.219 s Flash programming ... Programming completed in 1.828 s Content extract fail, continue anyway ... File Processed in 35.266 s Processing file: rh122_004.30aa as PPM [DCT4,DCT4 ALGORITHM] size: 2.53 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06:2984DA60 Area [01250000-0125FFFF] erased in 0.828 s Area [01260000-0174FFFF] erased in 1 min 3.421 s Flash programming ... Programming completed in 20.437 s File Processed in 1 min 35.969 s Flashing completed in 4 min 49.781 s Phone not responding ! Total time to process is 5 min 9.828 s hello what's wrong of this software |
08-03-2010, 10:32 | #5 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 843C 2208 0000 0040 C201 4000 00A2 6510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06A3BDA66 ASIC type: 11 UEM Imei: 35936403906885 Processing file: rh122_005.010 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 843C 2208 0000 0040 C201 4000 00A2 6510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06:2984DA60 Area [01000000-0100FFFF] erased in 0.844 s Area [01010000-0179FFFF] erased in 1 min 40.281 s Area [017A0000-017EFFFF] erased in 4.390 s Area [01F00000-01FDFFFF] erased in 0.765 s Flash programming ... Programming completed in 31.860 s File Processed in 2 min 28.891 s Processing file: rh122_005.01ae as PPM [DCT4,DCT4 ALGORITHM] size: 2.49 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 843C 2208 0000 0040 C201 4000 00A2 6510 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A1BB06:2984DA60 Area [01250000-0125FFFF] erased in 0.890 s Area [01260000-0174FFFF] erased in 1 min 5.563 s Flash programming ... Programming completed in 34.250 s File Processed in 1 min 51.734 s Flashing completed in 5 min 12.516 s Phone not responding ! Total time to process is 5 min 31.812 s FULL FACTORY... Failed! Completed in 0.719 s FULL FACTORY... Failed! Completed in 0.625 s FULL FACTORY... Failed! Completed in 0.625 s FULL FACTORY... Failed! Completed in 0.656 s |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
