2730c contact service, (ANSWERED) MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085A25A Using device: HTI, FW ver: 00.50, SN: 0000BD83 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 10C00105716902568E340D42ADC5177C4DA8FF17 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [***] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 e***ProtocolType: OLD Storage0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [*** ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 TransmissionMode: DDR&TX2 Original Imei: 35434304605846 Original Product code: 059D0Z3 Bluetooth ID: E4EC10CFB5FD Phone type: RM-578 (Nokia 2730 classic) SW version: V 10.45 05-07-10 RM-578 (c) Nokia Imei plain: 35434304605846-3 Product code: 0585565 Battery voltage: 4663 mV, current: 91 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR030102F201, ver: 005.005 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354343046058463 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host3, agent version 1.2 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.198.104.210 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->MXKEY - BLADE X at host3, agent version 1.2 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.198.104.210 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->MXKEY - BLADE X at host3, agent version 1.2 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.198.104.210 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->MXKEY - BLADE X at host3, agent version 1.2 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.198.104.210 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request.Pls tell me what is the problem |
I tried its successfully But problem Still |
backup full rpl & pm data for safety then click repair sd then load pm file from computer & click pmm auth wait untill it says pmm authorised then just press write button & u are done here........ |
click recovery cert..................... |
download good tested and full length pm and go pm section and load file then click PPM AUTH your problem is solved. |
- press repair SD, follow on screen message. - all be done very easy. anyway, there is an update http://forum.gsmhosting.com/vbb/f550...hread-1410959/ BR |
