06-30-2011, 18:32 | #3 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Bus chack MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0858BDF Using device: HTI BOX, FW ver: 00.17 Driver: ohci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 00EC 227A [Samsung ] Phone Type: RM-689 SW Version: V 02.51 29-07-10 RM-689 (c) Nokia Imei plain: 35487404374078-6 Product Code: 059B372 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MS Language Pack: - not available. Imei net: 35487404374078 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Scan phone Phone Type: RM-689 SW Version: V 02.51 29-07-10 RM-689 (c) Nokia Imei plain: 35487404374078-6 Product Code: 059B372 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MS Language Pack: - not available. Imei net: 35487404374078 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Or flash Mxbox phone dead |
06-30-2011, 18:33 | #4 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | flashing log. Backup saved to C:\mobileEx\3.5\data\backup\XGOLD_RM-689_7641CA5AEC10C083_IMEI.back MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0858BDF Using device: HTI BOX, FW ver: 00.17 Driver: ohci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 00EC 227A [Samsung ] Processing file: rm689_002.510 Downloading item CODE:hw_s01_rm689_r02.510.fls, num block: 3, size: 4.08 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 44.844 s Erasing area 0x00C60000-0x00E645BE ...OK Programming completed in 45.781 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.156 s Checksum verified (0x7AF5) Processing file: rm689_002.51ia Downloading item CUST:hw_s01_rm689_002.51ia.fls, num block: 1, size: 2.02 MB Erasing area 0x00210000-0x00414A7E ...OK Programming completed in 43.766 s Checksum verified (0x7C32) Processing file: rm6890_nai02.51ia Downloading item CUST:hw_s01_rm6890_nai02.51ia.fls, num block: 1, size: 327.45 KB Erasing area 0x00EB0000-0x00F010BE ...OK Programming completed in 7.046 s Checksum verified (0x02BE) Total time for flashing process(boot+erase+write) was 3 min 37.297 s Phone not responding ! |
06-30-2011, 18:40 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | can't understand your phone is now ok or not. bcoj u post scan log. last version is C1-00 (RM-689) Major 03.00 v11 (NDT) download and flash again. Blue-Nokia.com by Obnoxy BR |
06-30-2011, 19:04 | #6 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
same problem 03.00 v11 MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0858BDF Using device: HTI BOX, FW ver: 00.17 Driver: ohci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 00EC 227A [Samsung ] Processing file: rm689_003.000 Downloading item CODE:hw_s01_rm689_r03.000.fls, num block: 3, size: 4.11 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 45.266 s Erasing area 0x00C60000-0x00E6A87E ...OK Programming completed in 44.266 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.156 s Checksum verified (0x446F) Processing file: rm689_003.00ie Downloading item CUST:hw_s01_rm689_003.00ie.fls, num block: 1, size: 1.76 MB Erasing area 0x00210000-0x003D2B7E ...OK Programming completed in 38.203 s Checksum verified (0x2CF7) Processing file: rm6890_nai03.00ie Downloading item CUST:hw_s01_rm6890_nai03.00ie.fls, num block: 1, size: 327.45 KB Erasing area 0x00EB0000-0x00F010BE ...OK Programming completed in 7.047 s Checksum verified (0xDED7) Total time for flashing process(boot+erase+write) was 3 min 25.859 s Phone not responding ! | |
06-30-2011, 19:10 | #7 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | FLASHING with ATF !!! VBATT OFF... VBATT ON Setting VBATT Done!... Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_002.510 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 2A75 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2115008 bytes Data Checksum: DF0F Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_002.51ic PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003F7FBE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1998784 bytes Data Checksum: 9875 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm6890_nai02.51ic CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F013BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 332736 bytes Data Checksum: 678B Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:43 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.51 29-07-10 RM-689 (c) Nokia IMEI: 354874043740786 Product Serial Number: 1F000A8AH Product Code : 059B372 Module Code : 0204627 Basic Production Code: 059D336 MCU SW Version : V 02.51 29-07-10 RM-689 (c) Nokia IC ADSP Version : p V 02.51\n29-07-10\nRM-689\n(c) NMP\nic PPM Version : V 02.51 29-07-10 RM-689 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : INNO:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
06-30-2011, 19:18 | #8 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | yes Dear atf is good. but one thing mxbox steel needs many update. and we hope next time mx team give us good update and make it a good flashing interface. thanks BR |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
