02-08-2010, 18:56 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: anywhere
Member: 548078 Status: Offline Thanks Meter: 80 | 2760H convert to 2760 reboot here is the logs below... Imei net: 01149800024305 Version: SIMLOCK SERVER Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 PhoneType:RM-259 SwVersion: V 04.20 03-08-07 RM-259 (c) Nokia MCU file: rm258__04.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000FCF87:3B8ADA60 Area [01000000-0101FFFF] erased in 0.422 s Area [016C0000-016DFFFF] erased in 0.375 s Area [013E0000-013FFFFF] erased in 0.360 s Area [01480000-0149FFFF] erased in 0.375 s Area [01C20000-01C3FFFF] erased in 0.406 s Programming ... Programming completed. Phone not responding ! Phone not responding ! ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000FCF87:3B8ADA60 Area [01000000-0101FFFF] erased in 0.391 s Area [016C0000-016DFFFF] erased in 0.375 s Area [013E0000-013FFFFF] erased in 0.344 s Area [01480000-0149FFFF] erased in 0.391 s Area [01C20000-01C3FFFF] erased in 0.390 s Programming ... Programming completed. Retrying ... OK, case id: 4 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000FCF87:3B8ADA60 Area [01000000-0101FFFF] erased in 0.390 s Area [01080000-0109FFFF] erased in 0.391 s Area [01AC0000-01ADFFFF] erased in 0.422 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000FCF87:3B8ADA60 Area [01000000-0101FFFF] erased in 0.390 s Area [01080000-0109FFFF] erased in 0.391 s Programming ... Programming completed. Completed in 2 min 51.562 s Reading Simlock info ... Imei net: 01149800024305 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN ____________________________________________ update for high version... Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000FCF87A3BDA66 ASIC type: 11 UEM Imei: 01149800024305 Flash Imei: 01149800024305 MasterCode: 1577117501 RPL saved to "C:\mobileEx\3.3\data\backup\01149800024305_BACK.r pl" Phone Type: RM-258 (Nokia 2760) SW Version: V 05.62 02-07-08 RM-258 (c) Nokia Imei plain: 01149800024305-8 Imei OTP: 01149800024305 Product Code: 0550638 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: ED Language Pack: English,Croatian,German,Slovenian Imei net: 01149800024305 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
2760H Unlock And Convert To 2760 | vinay_sharma | Nokia Hardware & Hardware Repair | 24 | 08-23-2010 13:27 |
2760h converted in 2760 but! | principal | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-17-2009 22:40 |
convert rm391-2760h to 2760 rm258 | zkb | Nokia Hardware & Hardware Repair | 13 | 03-26-2009 23:22 |
after convert 2760h to 2760 only camera not work | genci titi 2002 | Nokia Hardware & Hardware Repair | 12 | 03-26-2009 17:20 |
