08-13-2011, 05:51 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: R A J A S T H A N
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | 3.5 rev 1.3 bug (ANSWERED) Not working bus chek after try backup RPL . If want to use Mxbox then reconnect n resstart software but other box working well :-?? |
08-13-2011, 07:06 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | must wait for 2min. same happend on me i think box is signing that is y it's to long to start after 2min software works fine |
08-13-2011, 14:57 | #5 (permalink) |
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | System: » OS version: 6.1.7600.16385(x86) - English (United States) Main: » mobileEx.exe, version: 3.4.0.8989, date: 6-08-2011 » mobileEx.lib, version: 1.0.0.12274, date: 06-08-2011 Modules: » alc.mx, library version: 1.0.0.17, module version: 1.01, date: 23-12-2010 » bb.mx, library version: 1.0.0.841, module version: 1.04, date: 06-08-2011 » ccs.mx, library version: 1.0.0.1288, module version: 1.02, date: 07-11-2010 » htc.mx, library version: 1.0.0.320, module version: 1.03, date: 07-11-2010 » huw.mx, library version: 1.0.0.109, module version: 1.02, date: 06-05-2010 » nk.mx, library version: 1.0.0.18624, module version: 1.21, date: 06-08-2011 » qcd.mx, library version: 1.0.0.1977, module version: 1.02, date: 06-08-2011 » siem.mx, library version: 1.0.0.293, module version: 1.01 B, date: 06-05-2010 » vcom.mx, library version: 1.0.0.1326, module version: 1.04, date: 23-06-2010 » voda.mx, library version: 1.0.0.43, module version: 1.00, date: 06-05-2010 » zte.mx, library version: 1.0.0.23, module version: 1.00, date: 20-11-2010 Loaded Drivers: » Nokia NMWCD, version: 7.1.32.67, date: 4-15-2011 » MXKEY TEAM WinUSB, version: 3.5.0.0, date: 9-6-2011 » FTDI FTDIBUS, version: 2.6.0.0, date: 10-22-2009 » SarasSoft UFS2XX, version: 3.8.14.0, date: 5-18-2011 its on 2nd time bus chek After press Abort then then need to close software by force bt task manager n reconnect box too ..... br |
08-13-2011, 16:04 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | RAP3Gv2 buscheck RPL BACKUP Code: Reading RPL backup ... Reading Phone IDs ... SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 52.99 KB Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Sending Overflow Loader(0x2E4 bytes) ... Overflow loader running .. Sending CustomLoader ...OK PUBLIC ID: 2DA0000852E38B5632F281DE04150F7963769199 PRIVATE ID: 1D3DA3A57B9281AE5493B4223D2B5BF555C8F037 E-FUSE: 025B2301 SEC ROM CRC: 40830040 productData saved. Restarting phone ... Reading Secure Storage ... Reading SIMLOCK data ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2DA0000852E38B5632F281DE04150F7963769199 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Flash Imei: 35606103329750 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SUPERDONGLE_KEY_DATA saved OK CMLA_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35606103329750_BACK.rpl" RAPIDO buscheck RAP3Gv4 buscheck - please check your FBUS cable, - change mini usb cable. - try to repair mxkey installation, delete, reinstall. - try to update box FW once more. |
08-14-2011, 14:37 | #8 (permalink) | |
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | Quote:
2- also changed mini USB cable 3- uninstall mxkey driver n box driver then uninstall mxkey software n delete all file from - C:\mobileEx then reinstallation of new software 4- Update box 2 time 5- Still same 6 - it was work fine with 1.2 why ? | |
08-14-2011, 14:40 | #9 (permalink) |
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | 3.5 rev 1.3 bug (ANSWERED) i dont understund ur mean ... without satisfied how to tell " (ANSWERED) " its only mean u complited ur duty .... Thanks manole sir |
The Following User Says Thank You to rekha1255 For This Useful Post: |
08-14-2011, 14:52 | #10 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | http://forum.gsmhosting.com/vbb/f550...fault-1325626/ http://forum.gsmhosting.com/vbb/f550...wered-1325132/ (ANSWERED) tags means, me, as a product supporter has taking care a thread. later it will be changed into (SOLVED) if needed - it is The Boss who told me to do so BR |
The Following User Says Thank You to gbluez For This Useful Post: |
08-14-2011, 17:47 | #12 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | mee to same 1- same cabel work well in other tool ( like HWK N ATF ) 2- also changed mini USB cable 3- uninstall mxkey driver n box driver then uninstall mxkey software n delete all file from - C:\mobileEx then reinstallation of new software 4- Update box 2 time 5- Still same 6 - it was work fine with 1.2 why ? Opetating system and installed anti virus cheked but same problame |
08-19-2011, 13:07 | #15 (permalink) |
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | Problem fix by me .... Im so sad n angry on team coz not proper help i was remove smart card n fix in old mxkey only card reader .. then problem fixed .. actually when we do bus check volt down in win usb n its not proper work to read smart card so stop in 2nd time bus check .. gbluez ur help is not work properly sorry to say Good bye you . I'll never ask Question to you . about Max key |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
