11-17-2009, 10:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | 3110 contact service Using device: J.A.F, FW ver: 01.B1 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 14000215433A7D56FDBA6C6121C5F96BD34CBBEE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Original Imei: 35683302870681 Original Product code: 0566963 Bluetooth ID: 0022FDF82E18 Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35683302870681-4 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei: 356833028706814 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-17-2009, 10:53 | #2 (permalink) |
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | here is pm auth report Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 117.194.36.39 SUPERDONGLE auth succeeded! |
11-17-2009, 10:56 | #3 (permalink) |
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | after sx4 and write modify pm, scan SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! problem remaim same how to solved this |
11-17-2009, 11:13 | #6 (permalink) |
Freak Poster Join Date: Dec 2006 Location: gsmworld of moderetso .
Member: 410890 Status: Offline Thanks Meter: 88 | do full erase but 1st backup all certificate or crt then fullflash again then write backup then sx4 auth again and write new pm modifiy with pm1 to pm309 only... |
11-17-2009, 11:21 | #7 (permalink) |
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | Completed in 0.516 s Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 117.194.36.39 SUPERDONGLE auth succeeded! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 2 - Key: 0, size 432 bytes written. Section: 4 - Key: 1, size 64 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 4 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 16 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 1, size 2 bytes written. - Key: 3, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 19, size 8 bytes written. - Key: 25, size 2 bytes written. - Key: 37, size 4 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 48, size 4 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 58, size 2 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 123, size 8 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 133, size 2 bytes written. - Key: 135, size 2 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. Section: 31 - Key: 4, size 12 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 80 bytes written. - Key: 1, size 2 bytes written. Section: 56 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. Section: 59 - Key: 0, size 63 bytes written. Section: 65 - Key: 0, size 11 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 11 bytes written. - Key: 3, size 11 bytes written. - Key: 4, size 11 bytes written. Section: 66 - Key: 0, size 160 bytes written. - Key: 1, size 160 bytes written. - Key: 4, size 160 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 160 bytes written. - Key: 10, size 240 bytes written. - Key: 12, size 4 bytes written. - Key: 14, size 4 bytes written. - Key: 16, size 4 bytes written. - Key: 17, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 19, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 36, size 4 bytes written. - Key: 38, size 4 bytes written. - Key: 40, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 64, size 8 bytes written. - Key: 65, size 8 bytes written. - Key: 66, size 8 bytes written. - Key: 67, size 8 bytes written. - Key: 68, size 8 bytes written. - Key: 70, size 8 bytes written. - Key: 82, size 8 bytes written. - Key: 83, size 8 bytes written. - Key: 84, size 8 bytes written. - Key: 86, size 20016 bytes written. - Key: 87, size 6144 bytes written. - Key: 88, size 300 bytes written. - Key: 89, size 40 bytes written. - Key: 99 skipped, frame length too long - Key: 104, size 43 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 2 bytes written. - Key: 118, size 4 bytes written. - Key: 120, size 4 bytes written. - Key: 121, size 4 bytes written. - Key: 122, size 4 bytes written. Section: 67 - Key: 0, size 2756 bytes written. Section: 76 - Key: 0, size 534 bytes written. Section: 84 - Key: 0, size 3 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 110 - Key: 0, size 6 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 19, size 40 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. Section: 182 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 183 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 184 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 185 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 186 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 187 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 188 - Key: 3, size 8 bytes written. - Key: 13, size 8 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 22, size 8 bytes written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 5 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 200 - Key: 0, size 5 bytes written. Section: 202 - Key: 4, size 42 bytes written. Section: 213 - Key: 0, size 20 bytes written. Section: 215 - Key: 0, size 84 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 225 - Key: 1, size 6 bytes written. - Key: 2, size 6 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 9, size 4 bytes written. Section: 238 Section: 250 - Key: 1, size 1116 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 392 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 319 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. Section: 321 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. Section: 322 Section: 334 Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4902 bytes written. Completed in 13.ror THERE IS ERROR WHILE WRITING IN SECTION 1 AND 309 |
Nokia 3110 Contact Service Problem | Weller | Nokia Hardware & Hardware Repair | 5 | 01-09-2010 06:58 |
3110 contact service- all ok but still contact | Riteshgpt60 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 01-03-2010 09:22 |
3110 contact service repair please | krona11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-17-2002 19:28 |
3110 contact service | SysIO | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-12-2001 10:32 |
