12-15-2009, 12:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: India Age: 40
Member: 181862 Status: Offline Thanks Meter: 38 | 3110c contact service............. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.10913, Date: 05-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 0A10011382BA7C56E3DD469961DFD3FD1E9B9B08 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Original Imei: 35683302524111 Original Product code: 0566963 Bluetooth ID: 0022FDF2E44E Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35683302524111-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2008-11-12T09:10:26Z SW Version: 07.21 Variant Version: 013 ProductProfile: RM237_0514950_07.21_013.spr Simlock: 0514950_simlock.bin Imei net: 356833025241112 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
12-15-2009, 13:58 | #4 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | Do you mean can't reach the server? If, yes try to reset NPC and write modified PM. write your RPL backup. Backup RPL and PM before do this. Contact Service may caused by corrupted PM (field 308), may need RPL calculation. Regards, |
12-15-2009, 14:15 | #6 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | 3110 cs problem solve by mx-key read full imei backup after make imei backup reset ncp option then flash with 7.21 version after flash write ur imei backup after write imei backup select modified pm file use pmauth option then write pm after write pm set is ok tested by me on 6 set' |
12-18-2009, 12:17 | #11 (permalink) | |
Member: 181862 Status: Offline Thanks Meter: 38 | Quote:
brother i did this way, but still problem is same,and i made one mistake i did'nt backup it's original pm file only i've it's RPL file pls help me | |
3110c contact service | zultopo | Nokia Base Band 5 ( BB-5 ) | 5 | 10-29-2010 11:33 |
3110c contact service and imei error | volmax® | MT-BOX | 10 | 04-18-2009 13:11 |
3110c Contact Service | zahed1978 | Nokia Hardware & Hardware Repair | 7 | 12-27-2008 21:13 |
