06-20-2011, 14:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | 3110c contact service pls help (ANSWERED) Here is all log what i do....................... Bus check ........................................ MXKEY Serial: [FT SCR2 0] - C08 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1C3000140D2B7E56ED8D17A422DEF5D28E8B564C ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Original Imei: 35934302474264 Original Product code: 0550542 Bluetooth ID: 00240408FBF7 Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302474264-6 Product Code: 0550542 Battery voltage: 4597 mV, current: 71 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359343024742646 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN salf test .................................................. ...................... Phone Type: RM-237 SW version: V 07.30 07-05-09 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N !FAILED(01) 71 BT_WAKEUP N !NOT EXECUTED(03) 99 IRDA_LED_STRESS N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) Super sd auth .................................................. .................................................. .. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 MXKEY Serial: [FT SCR20041F5 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1C3000140D2B7E56ED8D17A422DEF5D28E8B564C] ... Calculating using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Elapsed: 4.157 s (session timeout out after 3 second) repair sd MXKEY Serial: [FT SCR20041F5 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1C3000140D2B7E56ED8D17A422DEF5D28E8B564C] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 [CR2]BB5 remaining credit: 12 Completed in 5.891 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_359343024742646_SD.RPL" Updating SUPERDONGLE_KEY ...OK pmm auth .................................................. ................................................. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 MXKEY Serial: [FT SCR2000 0] - C08441F5 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1C3000140D2B7E56ED8D17A422DEF5D28E8B564C] ... Calculating using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Elapsed: 4.157 s (session timeout out after 3 second) Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 119.30.39.72 SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 0.594 s [B]Repair sp lock[/B] .................................................. ...................... BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN MXKEY Serial: [FT SCR2000 0] - C08441F5 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1C3000140D2B7E56ED8D17A422DEF5D28E8B564C] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 [CR2]BB5 remaining credit: 11 Completed in 5.500 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_359343024742646_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 359343024742646 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN .................................................. ............................................... Now tell me what to do ??????????? |
06-20-2011, 14:56 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Rangpur Bangladesh
Member: 526223 Status: Offline Sonork: 100.1605395 Thanks Meter: 106 | 1. First backup rpl (go imei and security tab, imei rebuild, backup rpl) 2. Erase old pm (go, pm tab, erase) 3. Reset npc data (go imei and security tab, reset NPC data)(must backup rpl before do this) 4. Erase pm again (go pm tab, erase) 5.Write rpl from backup (go imei and security tab, imei rebuild, restore imei) 6. Go pm tab, super sd auth or pmm auth, then write good or modified pm (must need pm 1 & 309) 7. Erase pm again 8. Recover CERT (go imei and security tab, imei rebuild, recover cert) 9. Give full factory reset your phone must come back from security test failed |
06-21-2011, 16:25 | #9 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | solution 1 - make super SD autehtification - tick load RFBB from server - write PM solution 2 - go to phone test - various - BB5 certificate validation if mismatch or bad certificate then - imei&security - recover certificate after any operation phone must be restarted with bus check BR |
06-21-2011, 16:45 | #10 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ropar
Member: 358277 Status: Offline Thanks Meter: 476 | hi dear if u dont have solution yet. add me in yahoo. in 10 min i will give u solution. & then share here . id- [email protected] |
06-23-2011, 11:42 | #14 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 406 | Quote:
SECURITY_TEST failed! pm 1-309 | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
