11-10-2009, 06:28 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Hello Br, Here 5130c contact service successfully repaired with mxley, This solution same procedure as 3110c any bb5 models, Please watch and repaire your bb5 phones then post reply with successfully repaired phones and logs, Here is the link below, http://www.ziddu.com/download/698967...moved.rar.html http://www.sendspace.com/file/2n5rjh |
The Following 4 Users Say Thank You to swechacnu For This Useful Post: |
04-27-2010, 20:33 | #5 (permalink) |
Insane Poster Join Date: Mar 2010 Location: KERALA Age: 47
Member: 1271453 Status: Offline Sonork: justin Thanks Meter: 6 | 3110 cs ...........................RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 119001050D327E562BEDD8FE97EB6D45437955D7 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D NPC verified Ok. Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35196303894899-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351963038948992 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-28-2010, 00:07 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | All said by PersianS. If this phone is "virgin" - it is recommended to use PMM Auth. But if this phone got repaired SD before, only use Super SD Auth. Write pm 1+309 after auth. done. BR |
3110c dead done by USB flashing | Mintsea | Universalbox | 1 | 03-29-2010 11:54 |
3110c contactservice | mangaraj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 11-10-2009 19:18 |
nokia 3310 4.45 4lock closed+contactservice+imei changed please help | sidharthaharish | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 02-04-2007 05:29 |
Solution for "CONTACTSERVICE"?? | Stryker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 01-20-2002 18:45 |
STRANGE ContactService IN 8210 5.21 PLEASE READ!!! | toldien | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-20-2001 02:34 |
