04-07-2010, 14:35 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | 3110c cs and mxkey server.[SOLVED] SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35483402240922-5 Product Code: 0548688 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 354834022409225 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
04-07-2010, 14:37 | #3 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | try to repair simlock --------- Product: V 07.21 05-11-08 RM-237 (c) Nokia. Using cached productData[2C400205CF417B56DC8FF7DCE57708FA937D8447] ... Calculating SIMLOCK using security server ... Completed in 1.469 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_354834022409225_SIM.RPL" Updating SIMLOCK...error 0x1 ------------------------------- try to repair sd. also recover cirt Calculating SUPERDONGLE using security server ... Completed in 2.594 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_354834022409225_SIMSD.RPL" Updating SUPERDONGLE_KEY ...error 0x0 Updating SIMLOCK...error 0x1 -------------------- also fone flashed |
04-07-2010, 14:42 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | bro, server work good try this backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd (you will get rpl to repair sim & sd) go to pm >click sd auth writ pm and wait 30 second u can see here relust http://forum.gsmhosting.com/vbb/f550...1/#post5679847 |
04-07-2010, 14:55 | #8 (permalink) | |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
how to erase | |
04-07-2010, 15:00 | #11 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | bro, Follow my steps backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd (you will get rpl to repair sim & sd) go to pm >click sd auth writ pm and wait 30 second |
04-07-2010, 15:03 | #14 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | |
04-07-2010, 15:06 | #15 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | [email protected] i have team viever can u help me |
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 629 | 07-07-2010 07:15 |
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 164 | 05-05-2010 12:17 |
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" | MANOLE | Service Products News & Updates | 0 | 02-07-2010 23:17 |
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-06-2010 10:30 |
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair | MANOLE | Service Products News & Updates | 0 | 02-06-2010 10:10 |
