01-05-2010, 07:52 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1196390 Status: Offline Thanks Meter: 5 | 3110c flashing error log here ------------------ Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0EF0000BB4767C5640FA5CF638FFCF301E81BA19 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Original Imei: 35681502180742 Original Product code: 0550573 Bluetooth ID: 0022FCF8AFE5 ----------------------------- after bus check i flashed...............log here -------------------------------------------- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0EF0000BB4767C5640FA5CF638FFCF301E81BA19 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 1.015 s CMT NOR area [000006C0-0001FFFF] erased in 0.078 s CMT NOR area [00020000-0007FFFF] erased in 1.063 s CMT NOR area [00080000-000DFFFF] erased in 0.141 s CMT NOR area [00100000-001FFFFF] erased in 0.281 s CMT NOR area [00200000-0031FFFF] erased in 0.297 s CMT NOR area [00320000-0105FFFF] erased in 3.094 s CMT NOR area [01060000-01067FFF] erased in 0.093 s CMT NOR area [01068000-0107FFFF] erased in 0.079 s Flash programming ... Error while programming [00] at 0xFFFFFFFF, Result: 0000 Flashing terminated with error(s) in 40.250 s RX Buffer: B37 --------------- plz expert tell me where is fault (software or hardware) thanks in advance |
01-08-2010, 04:18 | #11 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | No hw problem.Mx-key can't flash 3110c due to some bug tested on atleast 10 set.flashed succesfully by mt.Hope in next update problem solved. and in 1100 user code reset fails on every set. |
01-08-2010, 22:48 | #12 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
phone auto select in RX2 option. but if cable not have RX2 pin,software will be stop/error so, check cable / use other cable. check box interface br, | |
3110c flashing error | Jabir27 | Nokia Base Band 5 ( BB-5 ) | 10 | 03-06-2009 07:07 |
3110c flashing error | shadowdex | Universalbox | 1 | 05-06-2008 16:20 |
3110c flash error ... please help | hamid123 | Universalbox | 4 | 09-14-2007 15:26 |
