11-19-2011, 12:20 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 44
Member: 76882 Status: Offline Thanks Meter: 56 | 3110c SECURITY_TEST failed! 3110c SECURITY_TEST failed! repair simlock & superdongle, sd auth write pm 1 to 309 . and also tried full flash , erase pm wtrite pm 1to 309 . any other solution plz......... Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 3519xxxxxxxx Product Code: 0514950 Battery voltage: 4809 mV, current: 58 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351939032651279 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
11-19-2011, 12:50 | #3 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Quote:
100% solve | |
11-19-2011, 12:59 | #4 (permalink) | |
Junior Member Join Date: Oct 2011
Member: 1673829 Status: Offline Thanks Meter: 22 | Quote:
tick load rff bb from server > PMM Auth > write pm 1 & 309 after auth is successful......... | |
11-19-2011, 15:37 | #7 (permalink) |
Banned Join Date: Mar 2011
Member: 1543138 Status: Offline Thanks Meter: 21 | hey kiran say by to 3110c cs follow n post result here all security test failed 100% solution! Many people posted in this forum about security test failed ! we know that_______ when come security test failed ______ solution_____ 1. super sd auth or pmm auth __than write good or modified pm ( must need pm 1 & 309) or, 2. sd repair ___ super sd auth or pmm auth ____ than write good or modified pm ( must need pm 1 & 309) My question ______ when we not success by up system than what can we do for repair security test failed? yes! we have this solution______ 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab >repair sd then 7. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 8. erase pm again 9. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 10. give full factory reset 11.update sp lock your phone must come back from security test failed it is 100% tasted by shiva 09993264376. |
11-19-2011, 16:45 | #8 (permalink) |
Member: 76882 Status: Offline Thanks Meter: 56 | hello error step 9. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) Begin Certificate Request ... [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) Socket error (10061): Connection refused |
11-19-2011, 17:01 | #9 (permalink) |
Member: 76882 Status: Offline Thanks Meter: 56 | write rpl backup Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0514950)... OK Updating PSN (7F0821634)... OK Updating HWID (2000)... OK Updating LOCK ...OK Updating SUPERDONGLE_KEY ...OK Updating CMLA_KEY...OK Updating WMDRM_PD...OK Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0514950 Battery voltage: 4892 mV, current: 52 mA Language Pack: - not available. Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 how to fix ? |
11-19-2011, 17:01 | #10 (permalink) | |
Banned Join Date: Aug 2011
Member: 1638155 Status: Offline Thanks Meter: 5 | Quote:
hey kiran can u post prasent buschek or scan log here again plzzzzzzzz for better help.......... | |
11-19-2011, 17:06 | #11 (permalink) | |
hey kiran i think u have mistake with step 5 do again step 5 then continues.................then post result here......... | |
11-19-2011, 17:33 | #12 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | Quote:
First restore your imei U will got your imei from defoult mxkey backup directory Select 3110 pm file just select 1&309 Use sx4 than write Your problem will be solve . | |
3330 v 412 fail with dfs 211 | denn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-19-2001 22:06 |
In wintesla 3310, what does cobba parrarel failed means | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-18-2001 16:05 |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
