02-13-2011, 11:16 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | 3110c sim lock corrupted (ANSWERED) I tried all hit and trial methods but not successed Here are the logs After Scan Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 355535017*****-4 Product Code: 0544306 Language Pack: - not available. SIMLOCK_DATA corrupted! Simlock Info. SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1450001357D56B56419F40FB87A51C39C27B4A52] ... Calculating SIMLOCK using security server ... Reading Simlock info ... SIMLOCK_DATA corrupted! Update SPlock Updating SIMLOCK...error 0x14 missing NPC data in the RPL file, skipped. Certificate programmed successfully ! Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: - Product Code: 0544306 Language Pack: - not available. SIMLOCK_DATA corrupted! Need Immediate Help |
02-13-2011, 11:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: GSMKSA Team
Member: 1178222 Status: Offline Sonork: 100.1602620 Thanks Meter: 467 | 1st backup rpl and go> to advance >get address > un tike safe erase > click erase flash > after flash new version then > RESTORE IMEI > TRY REPAIR SIM LOCKUR PROBLEM SOLVED |
02-13-2011, 11:26 | #3 (permalink) | |
Member: 772651 Status: Offline Thanks Meter: 1,694 | Quote:
02-13-2011, 11:30 | #4 (permalink) |
Freak Poster Join Date: Sep 2010 Location: I M FOLLOWING YOU
Member: 1398435 Status: Offline Sonork: 100.1664179 Thanks Meter: 172 | 3110c all ok but contact service (security test failed write after auth 1,9) tested solution here. use only mx-key read npc data and save ur known location full erase by mx-key and flash leatest ver modifty npc data rpl 2 my geven 3110c data (help by pic) write modified rpl use pm option pm repair sd write auth full without 308 pm update simlock with use tik sim lock rpl option ur handset ok now tested solution in case pm and rpl both are currpted there4 flash full hanset with rpl data. rpl modify support follwing instruction first read npc data ur contact service hadset and save ur desktop open saved npc data file in notpad 2nd also open in notpad my geven file (3110c data) copy all txt my geven file's open data and paste ur npc data file my given location in pic. now save ur modify rpl file and reset all handset data (npc,ccc,hwc,varient) then write modify rpl. ur handset ok 10000000% i have tested many time note:take full rpl backup and full pm backup before use this solution. 3110c support data link following: http://rapidshare.com/files/445461206/3110c_data.rar Dnt forget say thanx |
The Following User Says Thank You to alwarmobile For This Useful Post: |
02-13-2011, 11:33 | #5 (permalink) |
02-13-2011, 12:24 | #8 (permalink) | |
Member: 1178222 Status: Offline Sonork: 100.1602620 Thanks Meter: 467 | Quote:
02-13-2011, 12:27 | #10 (permalink) | |
02-14-2011, 05:24 | #11 (permalink) | |
this way 10000% solved nokia then off Last edited by abidottupara35; 02-14-2011 at 05:29. | |
The Following User Says Thank You to abidottupara35 For This Useful Post: |
02-14-2011, 05:45 | #12 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | 3110 contec service use mx-key backup rpl go pm aria select 3110c full pm with lock aria repair sd use sx4 sd auth write pm if u ask overwrite lock aria or product u want to skip tick no it will take lock aria pm go security imei and security select simlock tick on 2nd opption repair sim lock and tick on last option last make sim lock rpl repair sim lock your problem 100000%solve if u like my post only say thanx |
02-14-2011, 06:23 | #13 (permalink) | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
