10-19-2010, 12:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: india Age: 43
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | 3110c SUPERDONGLE_KEY invalid! help me (ANSWERED) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35683302558304-2 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356833025583042 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to gkmobiles For This Useful Post: |
10-19-2010, 14:54 | #4 (permalink) |
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | 3110c SECURITY_TEST failed! Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35683302558304-2 Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356833025583042 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
10-19-2010, 14:56 | #5 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | bro first go to imei tab then click on "recover cert " after that load pm file without npc data then pmm auth when phone goes to superdongle auth then click on write solution tested 100% on this condition .. if not sucess then make feel free to contact me on yahoo([email protected] ) |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
10-19-2010, 17:02 | #7 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | that pm is on this address pl download from here http://www.4shared.com/file/1p0mGDas...M-237_rpl.html |
10-19-2010, 18:44 | #8 (permalink) |
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | SECURITY_TEST failed Write modified PM then Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Retrying ... any solution???? |
10-19-2010, 18:58 | #10 (permalink) |
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[22A001182CEB7C56C840C1D405CA310D432DE6F7] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Completed in 9.891 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_356833025583042_SD.RPL" Updating SUPERDONGLE_KEY ...OK SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
10-19-2010, 23:38 | #11 (permalink) |
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | 3110c SECURITY_TEST failed! help me 3110c SECURITY_TEST failed! Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35683302558304-2 Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed Imei net: 356833025583042 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
10-20-2010, 01:28 | #13 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | yes.. write pm 1 and 309 . if still same problem ,, then add me in your messenger LITTLE MASTER Last edited by MANOLE; 10-20-2010 at 19:37. Reason: if you need 1000 more users in your YM i give you mine YM ID |
10-20-2010, 01:32 | #14 (permalink) | |
Member: 1205146 Status: Offline Thanks Meter: 879 | Quote:
write pm 1 and 309 . if still same problem ,, then add me in your messenger LITTLE MASTER Last edited by MANOLE; 10-20-2010 at 19:38. Reason: if you need 1000 more users in your YM i give you mine YM ID | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
