05-19-2010, 10:28 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: OrbitGsm.Com
Member: 650840 Status: Offline Thanks Meter: 622 | 3110c WHERE"S THE FAULT??? I TRIED SO MANY TIMES TO DO SX4 & SUPPER SD AUTH.BUT ALWAYS GIVINGTHIS ERROR"Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request" THEN I TRIED TO DO SX4 ON 6303. IT WAS SUCCESSFUL SO,WHERE"S THE FAULT ON 3110C PHONE INFO:- Code: Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35681502491514-3 Product Code: 0550542 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356815024915143 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1660000444927C5621CAB6364C8912AAAC3238B6] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 119.30.39.89 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request BR, P@lash_c6 |
The Following 3 Users Say Thank You to palash_c6 For This Useful Post: |
05-19-2010, 10:36 | #4 (permalink) |
Freak Poster Join Date: Dec 2007 Location: kotli
Member: 643478 Status: Offline Sonork: 100.161898 Thanks Meter: 159 | yes i have sam problem after new vr 3.4.1.0 sx4 server is in prblem max team plz fix this erorrr |
The Following User Says Thank You to moon955 For This Useful Post: |
05-19-2010, 13:48 | #9 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
http://forum.gsmhosting.com/vbb/f550...swered-999587/ | |
05-19-2010, 20:26 | #14 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | backup rpl rest npc go to pm click erase pm writ rpl then click recover cert simlock> click splock info then tick make simlock rpl then click update simlock repair sd go to pm >tick load rfbb from server then click SUPER SD AUTH and writ pm fullfactory&format |
The Following 2 Users Say Thank You to alasmmar For This Useful Post: |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Ringtones from the charts and new Links | GM | GSM Mobile Links | 0 | 09-26-1999 13:54 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
