09-17-2009, 01:28 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: gorontalo
Member: 629228 Status: Offline Thanks Meter: 17 | 3500c SUPERDONGLE_KEY corrupted ! help! RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 0BC0010756AE6F5663ADB91CE6274BEBEF56E66D ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Original Imei: 35308002258755 Original Product code: 0549183 Bluetooth ID: 001F5CC10283 Phone Type: RM-272 (Nokia 3500c) SW Version: V 07.21 05-11-08 RM-272 (c) Nokia. Imei plain: 35308002258755-9 Product Code: 0549248 VariantId: X Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2008-11-14T08:15:26Z SW Version: 07.21 Variant Version: 006 ProductProfile: RM272_0549248_07.21_006.spr Simlock: 0549248_simlock.bin Imei: 35308002........ Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[nkrpl.biz] ...MXKEY-Server v2.4 hello 125.167.119.178 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request what is wrong superdongle or security? |
09-17-2009, 06:36 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
Hello Bro, Try some more times click the sx4 button some times server not recieving pmm auth, i have same problem some phones i do same procedure my problem is solv, try then post result. | |
The Following User Says Thank You to swechacnu For This Useful Post: |
09-17-2009, 20:46 | #5 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Brazil Age: 44
Member: 139167 Status: Offline Thanks Meter: 13 | see this thread http://forum.gsmhosting.com/vbb/showthread.php?t=686915 |
09-17-2009, 20:51 | #6 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | try downgrade and SX4 AGAIN if not slove ,save rpl and pm backup and make npc rest ,after this write pm and restore ur backup wbr |
The Following User Says Thank You to mohA™ For This Useful Post: |
SUPERDONGLE_KEY corrupted !-PLS HELP | vistasamir | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 03-27-2010 06:51 |
SUPERDONGLE_KEY corrupted problem | xvirus | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 09-10-2009 23:17 |
SUPERDONGLE_KEY corrupted !-PLS HELP | vistasamir | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 08-22-2009 07:04 |
6300 watchdog problem, Bad phones ack, probably SUPERDONGLE_KEY corrupted ! | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 08-14-2009 05:54 |
SUPERDONGLE_KEY corrupted | az_liton | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-24-2009 18:42 |
