07-25-2010, 08:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 159880 Status: Offline Thanks Meter: 60 | 5030 error in flashing language only heres the log: Using device: POTATO BOX, FW ver: 01.B0 Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00513C80A3BDA66 ASIC type: 11 UEM Imei: 35268604222259 Processing file: rm524_005.01ic as PPM [DCT4,DCT4 ALGORITHM] size: 2.53 MB Supported Ids: 2293 flashing terminated ! Flashing terminated with error(s) in 1 min 53.891 s RX Buffer: 33258606242252F942 |
07-25-2010, 17:40 | #7 (permalink) |
Member: 159880 Status: Offline Thanks Meter: 60 | i change my interface already but same problem...i try to full flash but not flashing error still coming Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Boot error: 02 FF FF 72 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Boot error: 02 FF FF 72 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Flashing terminated with error(s) in 1 min 23.328 s |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
