Old 07-24-2010, 11:28   #1 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
Thanks Meter: 473
.:5530xm after usb-flash successfull now vibrate only:.
hi MATES!
I received 5530XM for upgrade with installed version 11.0.054
I flashed the phone with v 20.0.080
HERe is the log--
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: RM-504_20.0.080_prd.core.C00 as MCU
 [BB5,XSR 1.5]  size: 101.85 MB
 Supported RAP Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Polling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3982F620
RAP SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 023001083F83005252948C2052D40B240C58BA0C
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
RAP ROM ID: 4B9B75103E691FF8
[ADL] Flashing CMT Update Server Data, ULO: 0x3B80 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, XSR: 0x2513A5 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 11722FE6
[ADL] Verifying communication to device OK.
Partitioning....
Partitioning complete
Erase size: 158.19 MB
Flash programming ...
CMT PAPUBKEYS: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF (RAP Certificate 168 v.1) written.
Programming completed in 1 min 19.532 s
Processing file: RM-504_20.0.080_prd.rofs2.V01 as PPM
 [BB5,XSR 1.5]  size: 23.75 MB
Erase size: 34.00 MB
Programming completed in 19.422 s
Processing file: RM-504_20.0.080_C01_prd.rofs3.fpsx as PPM
 [BB5,XSR 1.5]  size: 5.04 MB
Erase size: 11.00 MB
Programming completed in 4.328 s
Processing file: RM504_20.0.080_006_000_U001.uda.fpsx as CNT
 [BB5,XSR 1.5]  size: 4.89 MB
Erase size: 88.75 MB
Converting UCP blocks to 128 K.
Programming completed in 3.078 s
[ADL] Restarting phone ...
[ADL] Device found: nmwcdc\Nokia 5530 XpressMusic USB Generic, ID: 36DA24A4
Flashing completed in 3 min 23.969 s
Phone Type: RM-504 (Nokia 5530 XpressMusic)
SW Version: V ICPR72_09w36.5 25-09-09 RM-504 (c) Nokia
Imei plain: 35825303734318-6
Product Code: 0591601
ApeCoreSw: V 20.0.080
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358253037343186
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 3 min 27.938 s
Nokia USB ROM detached.
Now phone only vibrates phone is in local mode when finished flashing but now only vibrate!! Battery is fully charged and ok!!
Urgent help needed
Azeem ...thanks
The Following User Says Thank You to azeem781986 For This Useful Post:
Old 07-24-2010, 11:30   #2 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
which package you used
EMA or APAC ?
Old 07-24-2010, 11:37   #3 (permalink)
jci
jci's Avatar
Member: 344552
Thanks Meter: 25
sir use latest version flash file same this V30.00
download Here new update flash file>>>http://downloads.************.org/in...0%28RM-504%29/
Old 07-24-2010, 11:40   #4 (permalink)
Member: 503161
Sonork: 100.1584069
Thanks Meter: 473
I used this version bro
RM-504_EUROPE_20.0.080_v3.0
Old 07-24-2010, 11:40   #5 (permalink)
Member: 503161
Sonork: 100.1584069
Thanks Meter: 473
hmm..Well now download v30.
Hope will b successfully
thanks -will try and post result
Old 07-24-2010, 15:04   #6 (permalink)
Member: 503161
Sonork: 100.1584069
Thanks Meter: 473
Hello All phone done with other tool
Plz mx key team do something for these phones like 5530xM etc
With same ver 20 phone revived but with mxkey vibrate only -
Mxkey team please give some updates to these phones flashing thanks for best support
Regards
azeem
Old 07-25-2010, 17:20   #7 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Alim is working very hard and constantly to update his software.
I am glad to see you solve the problem with other tool,
i am not happy to see you was not able to do it with MXKEY.
BR,
Manole
The Following 2 Users Say Thank You to MANOLE For This Useful Post:
Old 08-24-2010, 20:09   #8 (permalink)
Member: 767332
Sonork: nickardo
Thanks Meter: 22
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 5C372CA
RAP PUBLIC ID: 16800116E77D0052A13EA8B62826DC060FE2B977
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 224D5370
Partitioning....
Programming completed in 1 min 0.640 s
[ADL] Device found: nmwcdc\Nokia 5530 XpressMusic USB Generic, ID: 1E30C3F8
Flashing completed in 1 min 53.671 s
Imei plain: 35420003031539-2
Product Code: 0587353
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 354200030315392
Counter: 0/3, 0/10
Total time to process is 1 min 56.656 s
Nokia 5530 flash sucessful with new mx-key version way to go mx-key there is th log post above
The Following User Says Thank You to nickardo For This Useful Post:
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Page generated in 0.18507 seconds with 9 queries
