10-24-2012, 08:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: AT YOUR EYES
Member: 747386 Status: Offline Thanks Meter: 30 | 5130 contect service nokia 5130 contect service here is logs MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D Using device: HTI, FW ver: 00.50, SN: 010016CF Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0F40020D9FA77D566A7DC75502DF93417C9D6AA8 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Selected firmware certificate matched. Original Imei: 35417903621790 Original Product code: 0572174 Bluetooth ID: 002548246EB0 SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35417903621790-3 Battery voltage: 4867 mV, current: 63 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
10-24-2012, 09:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, You know it's SL3 Phone. If Backup RPL All Section their in PC, Write RPL Manually will do the Job, Or else have to Buy Factory RPL. BR, ZUBER |
10-24-2012, 09:19 | #3 (permalink) | |
Member: 747386 Status: Offline Thanks Meter: 30 | Quote:
HRER IS BACKUP RPL LOGS Reading RPL backup ... Reading Secure Storage ... Reading Important data ... Reading SIMLOCK data ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0F40020D9FA77D566A7DC75502DF93417C9D6AA8 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Flash Imei: 35417903621790 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35417903621790_BA CK.rpl" | |
10-24-2012, 09:19 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: heLL and beY0nd
Member: 281801 Status: Offline Sonork: 100.1608672 Thanks Meter: 158 | Hello Zuber! I dont think the guy problem is IMEI issue. Backup rpl can only restore phone IMEI and the phone IMEI seems to be OK. SO, Having a full PM backup or PM 120 will solved his problem. ~Or Full flash Backup and restore Simlock {function in BEST or A.T.F} SIMLOCK TEST failed ~ReGaRds |
10-24-2012, 09:58 | #5 (permalink) | ||
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Do you read my post carefully before, If don't know then keep Quit, Do you Know RPL Contains Simlock Data? Select All Section on IMEI & Security Tab & Click Backup RPL, Will saved NPC, Simlock Data, All Certificates & PM. if don't know, then watch my Logs or can check with your own. Quote:
I think you got it now. Better not to recommend Other Tools(Crap) here, The HTI Box Functions cannot compare with others. BR, ZUBER | ||
10-24-2012, 10:22 | #6 (permalink) | |
br Zuber i have backup rpl and pm but log is change here is logs Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35417903621790-3 Product code: 0571584 Battery voltage: 4879 mV, current: 55 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: 002.012 SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! | |
10-24-2012, 10:30 | #7 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi Friend, Simlock Data Corrupted, Empty in your Backup RPL, may not Backup All Section. If you Readed & Backed up Sim RPL before will work in this case, At last Buy Factory RPL. BR, ZUBER |
10-25-2012, 08:20 | #9 (permalink) | |
You're right, Writing same as you mention will write all fields including IMEI, Simlocks, Certificates etc. Restore IMEI will only write NPC, means only IMEI & no other Data. BR, ZUBER | |
