Old 07-28-2010, 14:01   #1 (permalink)
Member: 241650
Thanks Meter: 71
Originally Posted by ..::kashif::.. View Post
1.scan...
[php]phone type: Rm-303 (nokia 5310 xpressmusic)
sw version: V 08.32 23-07-08 rm-303 (c) nokia
imei plain: 35417102352106-6
product code: 0548080
language pack:
- not available.
simlock invalid!
superdongle_key invalid!
- wd timer enabled, phone will reboot itself after 3 min.
simlock_test failed!
security_test passed
timestamp: 2009-03-25t13:21:23z
sw version: 10.10
variant version: 020
productprofile: Rm303_0548080_10.10_020.spr
simlock: 0548080_simlock.bin
simlock_data corrupted!
2-repair simlock(make simlock rpl,update simlock)
Using device: Ufs_usb v2.8 (c) sarassoft 2007.
Library version: 1.0.0.11985, date: 03-02-2010
product: V 08.32 23-07-08 rm-303 (c) nokia
system asic id: 000000010000022600010006010c192101013000
root key hash: Baf3a9c3dbfa8454937db77f2b8852b1
rom id: 273f6d55dfaaf68f
sending secondaryboot ...ok
sending preloader ...ok
sending customloader ...ok
calculating simlock using security server ...
Connecting to server[main.mxkey.biz] ...
Connecting to server[main.mxkey.biz] ...ok, secure login ...
Completed in 33.750 s
rpl saved to "c:\mobileex\3.3\data\backup\bb5_rm-303_354171023521066_sim.rpl"
updating simlock...ok
reading simlock info ...
Imei net: 354171023521066
version: Simlock server
provider: Nokia test, country: Finland
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block 1: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 2: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 3: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 4: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 5: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 6: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 7: 1=open 2=open 3=open 4=open 5=open, data=ffffff
3-scan (sl data repair done,but sd data still invalid)
language pack:
- not available.
simlock seems to be valid
simlock_test passed
sw version: 10.10
imei net: 354171023521066
counter: 0/3, 0/10
4-repair sd
using device: Ufs_usb v2.8 (c) sarassoft 2007.
calculating superdongle using security server ...
Completed in 29.922 s
rpl saved to "c:\mobileex\3.3\data\backup\bb5_rm-303_354171023521066_sd.rpl"
updating superdongle_key ...ok
5-super sd auth then write pm 1-309
restarting phone ...
Authenticating to superdongle using security server ...
superdongle authorized !
Writing pm from node ...
Section: 1
- key: 0, size 12 bytes written.
- key: 2, size 70 bytes written.
- key: 3, size 70 bytes written.
- key: 4, size 70 bytes written.
- key: 6, size 276 bytes written.
- key: 7, size 276 bytes written.
- key: 8, size 276 bytes written.
- key: 10, size 384 bytes written.
- key: 11, size 384 bytes written.
- key: 12, size 384 bytes written.
- key: 14, size 384 bytes written.
- key: 15, size 384 bytes written.
- key: 16, size 384 bytes written.
- key: 17, size 32 bytes written.
- key: 19, size 16 bytes written.
Section: 309
- key: 0, size 4 bytes written.
- key: 1, size 2 bytes written.
- key: 2, size 12 bytes written.
- key: 4, size 12 bytes written.
- key: 5, size 12 bytes written.
- key: 7, size 12 bytes written.
- key: 8, size 12 bytes written.
- key: 17, size 12 bytes written.
Completed in 1.844 s
6-all done!
language pack:
- not available.
superdongle_key seems to be valid
simlock_test passed
sw version: 10.10
counter: 0/3, 0/10
thanks mx-key softwer
good tool nokia
thanks
:::br:::
...::kashif::...
where's the 5130 solution?
The Following 2 Users Say Thank You to ruvan For This Useful Post:
Old 07-28-2010, 14:03   #2 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
Thumbs up kashif
man u just post the solution for 5310x not for 5130x it is old thing since 5310 is sl2
The Following User Says Thank You to Raznet For This Useful Post:
Old 07-28-2010, 14:05   #3 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
Thumbs up kashif
Old 07-28-2010, 14:11   #4 (permalink)
gsm_doc's Avatar
Member: 967780
Sonork: 100.1587141
Thanks Meter: 75
just wasting of time
Old 07-28-2010, 14:15   #5 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
Originally Posted by ..::KASHIF::.. View Post
1.scan...
[PHP]Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 08.32 23-07-08 RM-303 (c) Nokia
Imei plain: 35417102352106-6
Product Code: 0548080
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
TimeStamp: 2009-03-25T13:21:23Z
SW Version: 10.10
Variant Version: 020
ProductProfile: RM303_0548080_10.10_020.spr
Simlock: 0548080_simlock.bin
SIMLOCK_DATA corrupted!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 08.32 23-07-08 RM-303 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006010C192101013000
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SIMLOCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-303_354171023521066_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SW Version: 10.10
Counter: 0/3, 0/10
4-repair SD
Calculating SUPERDONGLE using security server ...
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-303_354171023521066_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 12 bytes written.
- Key: 2, size 70 bytes written.
- Key: 3, size 70 bytes written.
- Key: 4, size 70 bytes written.
- Key: 6, size 276 bytes written.
- Key: 7, size 276 bytes written.
- Key: 8, size 276 bytes written.
- Key: 10, size 384 bytes written.
- Key: 11, size 384 bytes written.
- Key: 12, size 384 bytes written.
- Key: 14, size 384 bytes written.
- Key: 15, size 384 bytes written.
- Key: 16, size 384 bytes written.
- Key: 17, size 32 bytes written.
- Key: 19, size 16 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
6-all done!
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 10.10
Counter: 0/3, 0/10
thanks MX-KEY Softwer
GOOD TooL Nokia
thanks
:::BR:::
...::KASHIF::...
its not 5130c ....................ur phone logs is 5310
Old 07-28-2010, 14:23   #6 (permalink)
mianjabbar's Avatar
Member: 481915
Sonork: 100.1604233
Thanks Meter: 476
hahahaha 5130..............
Old 07-28-2010, 14:27   #7 (permalink)
faisal4friend's Avatar
Member: 262523
Sonork: 100.1611482
Thanks Meter: 288
mr.kashif we know how to repair 5310 contact service but where is solution 5130 contact service where brooooooooooo.....
Old 07-28-2010, 15:06   #8 (permalink)
redrose2009's Avatar
Member: 1084993
Sonork: 100.1617420
Thanks Meter: 641
your model is sl2 5310 RM-303 contact service model is sl3 5130 495
post correct solution brother
Old 07-28-2010, 15:10   #9 (permalink)
Member: 1305533
Sonork: 008615013058388
Thanks Meter: 6
fail for 5130 , it is 5310 . it is mistake !!!!!!
Old 07-29-2010, 05:41   #10 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,131
Its 5310(SL2) not 5130(SL3) ok , so y u wrote here 5130 repair
ur post is only waste of time , Every one knows SL2 Simlock Repair
Posible and U think u r the 1 who repair Simlock data of 5310(SL2) First in the WORLD
The Following User Says Thank You to Ramzan For This Useful Post:
Old 07-29-2010, 06:07   #11 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
There are either 1000 of liars in the forum or they don't know what is different between SL2 and SL3?
Old 07-29-2010, 06:48   #12 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Sonork: 100.1651201
Thanks Meter: 229
NOt possible at tins moment
Old 08-22-2010, 12:10   #13 (permalink)
Member: 116294
Thanks Meter: 20
Originally Posted by ramzan View Post
its 5310(sl2) not 5130(sl3) ok , so y u wrote here 5130 repair
ur post is only waste of time , every one knows sl2 simlock repair
posible and u think u r the 1 who repair simlock data of 5310(sl2) first in the world
:d:d:d:d:d:d:d:d:d:d
Old 08-22-2010, 12:38   #14 (permalink)
Member: 1169642
Sonork: 1587581
Thanks Meter: 234
confusion tread ............................
Old 08-22-2010, 13:01   #15 (permalink)
Member: 392149
Thanks Meter: 199
Bro it is know evryone it is SL2 not SL3 model dont useless creat post
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
5130 5190 6190 MGG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-03-2000 20:36
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.29733 seconds with 9 queries
