5130 strange problem HI, I have one 5130 comes with contact service(superdongle key corrupted) as of know i want to repair it temporarily so i do RESET NPC to remove contact service even if it will restart after 5 min...and after NPC i flash it but error occur and now the phone is dead, i erase it with mx and again when i flash with last version it always error shows error -here is the log; Using device: UFS_USB V2.8 (c) SarasSoft 2007. Processing file: rm495__06.94.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.17 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 0890000F0E9D7D56BF0AA3012C04C3C61877D01D ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Total erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.641 s CMT NOR area [000006C0-0001FFFF] erased in 0.062 s CMT NOR area [00040000-000BFFFF] erased in 2.484 s CMT NOR area [000C0000-0013FFFF] erased in 0.141 s CMT NOR area [00140000-0137FFFF] erased in 1 min 17.281 s CMT NOR area [01380000-0151FFFF] erased in 8.250 s Flash programming ... Valid PAPUB key found CMT PAPUBKEYS, RAP Certificate 164 v.1 written. Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x01060400, Result: 0010 Flashing terminated with error(s) in 3 min 58.657 s RX Buffer: C7012D0103CD000010000000F172 I want to know What is this error indicate. And is there any solution to make this phone alive. |
Flash yr phone other device 100% tested like Jaf Hwk mt ect. i face same sitituion with nokia 5220 i totly flash it with jaf but not power up then i use hwk after that i again with jaf its work ok |
best thing try dead usb flash |
hi, there are two possibility for you case: 1st reason is flash loader, and the second is bad cable. please try with usb flashing. make sure you are using the latest version for your 5130. If the problem still the same, fix your flash folder (re-install mxkey) br |
Processing file: rm495__06.94.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.17 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Phone must be switched off. Press phone's POWER button or connect a CHARGER now ! warning: Some new phones consume more power, please connect cable to USB host instead of USB hub. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic-bf2166 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM1 ID: 00000296 RAP EM2 ID: 00000B22 RAP PUBLIC ID: 0890000F0E9D7D56BF0AA3012C04C3C61877D01D RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, UPDAPP: 0x49EC0 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x58400 bytes [ADL] Update Server code succesfully sent to phone [ADL] Pooling for ADL device [ADL] Timeout, no device not found. Flashing terminated with error(s) in 35.125 s RX Buffer: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000 i used 7 pin gpg cable and also i try with 3.2 ver5, when not success with ver5.2 |
http://i34.tinypic.com/2mciwba.jpg |
use latest version v3.2 revision 5.3, Public-Release |
Please Help!!!!!! Phone comes in contact service but dead now |
hello dear try other device |
I have mx, jaf,ufs3. with jaf-failed aborting, with ufs-http://i34.tinypic.com/2mciwba.jpg. Phone is dead now |
i got just the some problem ,now is solved by fixing flash loader |
may i know how to fix flashloader. how about klik update loader..? i got some problem on some bb5. but fortunatly if i klik check 2nd or 3rd after klik restart. its become ok.. |
after usb flash in mxkey Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm495__07.95.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.20 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 451404D RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 1050020D6FA27D56582B52E744D02B067607DA1C RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Polling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 54.219 s |
