05-24-2011, 06:36 | #1 (permalink) |
Insane Poster Join Date: May 2011
Member: 1580351 Status: Offline Thanks Meter: 2 | 1208 imei (ANSWERED) Help me please. |
05-24-2011, 07:05 | #3 (permalink) |
Member: 1580351 Status: Offline Thanks Meter: 2 | BR I have writen another pm,then have done unlock bat no rezults,Phone working 10 second and then swiched off. this is log Imei net: 35486802732579 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Rpl backup saved to "C:\mobileEx\3.5\data\backup\RH-105_35486802732579_SIM.RPL" Updating SIMLOCK ...ERROR: 07 Reading Simlock info ... Imei net: 35486802732579 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-24-2011, 07:18 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | brother ur imei ????????????4.ur rpl is corrupted.first flash ur phone .then use online logger to write rpl.ur phone off after 29 second becoz ur rpl damged. go to service tab then imei&scurity tab then select online logger then login and then tick dcr4plus and do select job/ if u not understand then se videos.. Mx kye_Rpl Write Video Tested.zip - 4shared.com - online file sharing and storage - download |
05-24-2011, 07:25 | #5 (permalink) | |
Member: 1580351 Status: Offline Thanks Meter: 2 | Quote:
05-24-2011, 07:31 | #6 (permalink) | |
I have done step by step this is a log but the same problem Updating SIMLOCK ...ERROR: 07 Reading ASK DATA ... ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00023FAAA3BDA66 ASIC type: 11 UEM Imei: 35486802732579 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35486802732579.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00023FAAA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-105 SW Version: V 6.00 30-09-09 RH-105 (c) NMP Imei plain: 35486802732579-6 Product Code: 0560686 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EO Language Pack: - not available. Imei net: 35486802732579 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | |
05-25-2011, 01:02 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, what is your phone condition actually? from this logs all OK Quote:
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
