01-11-2010, 10:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | 5130c Cantact Service possible to Repair SW version: V 06.65 01-04-09 RM-495 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N !no signal 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N !no signal 2 CURRENT_CONS N passed 42 RADIO N passed 69 BACKLIGHT Y passed 33 SIM_LOCK N !failed ! 93 SECURITY N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N !no signal 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal .................................................. .............................. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35932902592735-1 Product Code: 0576616 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
01-11-2010, 10:35 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | i have got also a set 5130c that is contact service if there is any solution with mxkey so plz help Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35422303867152-5 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
01-11-2010, 10:43 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Quote:
Can't be repaired as there is no tool which can repair Superdongle key of Sl3 phone. Possible Solutions:. 1.buy nokia original Rpls (Server closed so no way) 2.Claim warranty from Nokia original Sources. 3.Return the phone to customer(This is the last solution) | |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
01-11-2010, 12:59 | #15 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | ME TOO HAVE 7210c, 5130c AND 2700c SAME PROBLEM 7210c BUS CHECK Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1D400215219E7C56307780AEE0B7542B95E71CB3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Original Imei: 35931002668508 Original Product code: 0572571 Bluetooth ID: 002404D69598 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35931002668508-1 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Code: Version Info: MCU SW version: V 07.23 17-07-09 RM-436 (c) Nokia RFIC version: 064c0601 DSP version: ICPR72_09w17 LCD version: SHARP PPM version: V 07.23 17-07-09 RM-436 (c) Nokia MR BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Content Pack version: Content: mr V 07.23 12-08-09 RM-436 (c) Nokia Product Info: Production serial number: 0 Long production SN: 0 Serial Numbers: IMEI plain: 359310026685081 IMEI spare to net: 3A 95 13 00 62 86 05 08 IMEI SV to net: 33 95 13 00 62 86 05 48 F0 Other Info: Model : Nokia 7210 Supernova (Live) CS type : GSM900/GSM1800/GSM1900 BSI: 5.6 KOhm SIMLOCK_DATA corrupted! 5130c BUS CHECK Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 15800118AC087D56B8C99B3F24EADF6B47D92548 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35932902641972 Original Product code: 0577794 Bluetooth ID: 00247C448B40 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35932902641972-1 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed "C:\Program Files\Nokia\Phoenix\Products\RM-495" folder created. SIMLOCK_DATA corrupted! READED INFO Code: Version Info: MCU SW version: V 06.65 01-04-09 RM-495 (c) Nokia HW version: 1000 RFIC version: 06540601 DSP version: ICPR72_09w03 LCD version: SEIKO PPM version: V 06.65 01-04-09 RM-495 (c) Nokia MH BT MCM version: 2222-143C Retu version: 16 Tahvo version: 22 Content Pack version: Content: mh_blu V 06.65 01-04-09 RM-495 (c) Nokia Product Info: Production serial number: HEC345703 Product code: 0571584 Module code: 0204024 Basic production code: 0567773 Long production SN: 0 Serial Numbers: IMEI plain: 359329026419721 IMEI spare to net: 3A 95 23 09 62 14 79 02 IMEI SV to net: 33 95 23 09 62 14 79 32 F2 Other Info: Model : Nokia 5130c-2 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 4.2 KOhm SIMLOCK_DATA corrupted! 2700c BUS CHECK Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 25D00011686B63508C37C9C41CAE6C12A6ADD2A4 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F Original Imei: 35694603657719 Original Product code: 0579811 Bluetooth ID: 9C18746C567B Phone Type: RM-561 (Nokia 2700 classic) SW Version: V 07.15 04-06-09 RM-561 (c) Nokia Imei plain: 35694603657719-9 Product Code: 0588814 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed "C:\Program Files\Nokia\Phoenix\Products\RM-561" folder created. SIMLOCK_DATA corrupted! READED INFO Code: Version Info: MCU SW version: V 07.15 04-06-09 RM-561 (c) Nokia HW version: 2000 RFIC version: 06000601 DSP version: ICPR72_09w15 LCD version: SEIKO PPM version: V 07.15 04-06-09 RM-561 (c) Nokia MH Retu version: 16 Tahvo version: 22 Content Pack version: Content: mh_black V 07.15 04-06-09 RM-561 (c) Nokia Product Info: Production serial number: ICS829625 Product code: 0588814 Module code: 0204245 Basic production code: 0577212 Long production SN: 0 Serial Numbers: IMEI plain: 356946036577199 IMEI spare to net: 3A 65 49 06 63 75 17 09 IMEI SV to net: 33 65 49 06 63 75 17 39 F6 Other Info: Model : Nokia 2700 classic (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 4.4 KOhm SIMLOCK_DATA corrupted! HOPE WE WILL GET THE NEW UPDATE SOON. WBR sahil2000ind |
7210c possible to repair contect service with ub | Afzal Chiri | Universalbox | 34 | 07-10-2010 10:21 |
5130c contact service possible to repair? | suneel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-18-2010 07:05 |
5130c cantact service | lahdache | HWK | 14 | 01-01-2010 19:57 |
5130c is possible to repair cs | robean | Universalbox | 2 | 12-14-2009 13:06 |
E250D limited service it's possible to repair with UST ? | mahcin | UST Pro II | 13 | 02-21-2009 18:09 |
