02-03-2010, 05:28 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Stop WAR on GSM Business
Member: 328416 Status: Offline Thanks Meter: 42 | 5130c Contact Service.. Library version: 1.0.0.11866, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1A000103AABC7E56AEE85B8D37424785C4125128 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 3552320319xxxxx Original Product code: 0576616 Bluetooth ID: 0025CFEF0C9A Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35523203199xxxxx Product Code: 0576616 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! "RM-495" folder created. Imei net: 35523203199xxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-03-2010, 06:28 | #6 (permalink) |
Member: 328416 Status: Offline Thanks Meter: 42 | Done....... Code: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11866, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1A000103AABC7E56AEE85B8D37424785C4125128 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35523203199198 Original Product code: 0576616 Bluetooth ID: 0025CFEF0C9A Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 3552320319xxxx Product Code: 0576616 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355232031xxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Procedure: 1. Backup RPL 2. Backup Full PM 3. Click PM Auth (SX4 Authorization) 4. Write Back your previous Backup Full PM 5. Done... Note: I tried using modified PM but its turn the Phone CS Again Simlock Invalid... so I decided to write back the RPL and Full then Do SX4 authorization then write back the backup pm.. then success....... |
The Following User Says Thank You to ASHRIFF For This Useful Post: |
02-03-2010, 11:41 | #7 (permalink) |
Freak Poster Join Date: May 2009 Location: Hazaribag Age: 35
Member: 1040838 Status: Offline Sonork: 123 Thanks Meter: 29 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07A00013A5DD7D567D2F9E77DD1F4324B0E8144F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35422303021903 Original Product code: 0577793 Bluetooth ID: 0025487AFDA3 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35422303021903-4 Product Code: 0577793 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted |
02-03-2010, 11:42 | #8 (permalink) |
Member: 1040838 Status: Offline Sonork: 123 Thanks Meter: 29 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07A00013A5DD7D567D2F9E77DD1F4324B0E8144F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35422303021903 Original Product code: 0577793 Bluetooth ID: 0025487AFDA3 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35422303021903-4 Product Code: 0577793 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted plese help sir |
NOKIA 5130c CONTACT SERVICE | ami tomar | Nokia Base Band 5 ( BB-5 ) | 30 | 08-27-2011 21:03 |
Nokia 5130c contact service | UNLOCK PARK ® | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 11-25-2010 09:41 |
5130c Contact Service DONE by Cyclone | Code:L.A 22 | Cyclonebox | 16 | 09-12-2009 10:09 |
5130c contact service pls help this kind of problem | justine54 | Nokia Base Band 5 ( BB-5 ) | 11 | 09-06-2009 20:09 |
