02-04-2010, 01:43 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1141264 Status: Offline Thanks Meter: 6 | help this bugs or my mxkey erorr buschek Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D53441A3BDA66 ASIC type: 11 UEM Imei: 35679402053361 Flash Imei: 35679402053361 MasterCode: 4256551770 RPL saved to "C:\mobileEx\3.3\data\backup\35679402053361_BA CK.r pl" Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: 35679402053361-6 Product Code: 0549920 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MD Language Pack: - not available. Failed to read SP data kalo flash kayk gn gak mau lokal maode jadinya contact service Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D53441A3BDA66 ASIC type: 11 UEM Imei: 35679402053361 Flash Imei: 35679402053361 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\3567940205336 1_BA CK.rpl" Processing file: rh105_05.910 as MCU [DCT4,DCT4 ALGORITHM] size: 2.28 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D53441:2984DA60 Area [01000000-0100FFFF] erased in 1.156 s Area [01010000-013AFFFF] erased in 1 min 6.890 s Area [013B0000-013EFFFF] erased in 4.625 s Area [017C0000-017EFFFF] erased in 0.094 s Area [01FC0000-01FEFFFF] erased in 0.078 s Flash programming ... Programming completed in 17.281aa s File Processed in 1 min 40.718 s Processing file: rh1050_nai5.91md as CNT [DCT4,DCT4 ALGORITHM] size: 147.47 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D53441:2984DA60 Area [01380000-013AFFFF] erased in 3.453 s Flash programming ... Programming completed in 1.157 s Content extract fail, continue anyway ... File Processed in 43.157 s Processing file: rh105_05.91md as PPM [DCT4,DCT4 ALGORITHM] size: 1.25 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D53441:2984DA60 Area [01240000-0124FFFF] erased in 1.172 s Area [01250000-0137FFFF] erased in 21.828 s Flash programming ... Programming completed in 9.531 s File Processed in 43.015 s Flashing completed in 4 min 5.203 s Phone not responding ! Total time to process is 4 min 25.750 s but if i use hwk problem solved newbie sedang belajar |
is this bugs or what always appear on bb5 flashing | rock23 | Cyclonebox | 6 | 05-21-2009 14:34 |
Bug or my fault pls help | ..::GsmHelp::.. | FuriousGold | 1 | 01-03-2008 21:44 |
is this bug or newloader???? | smartecs | Universalbox | 0 | 08-31-2007 12:25 |
is this BUG or what ? | ..::Mr999::.. | Ultima Box Light | 7 | 08-15-2007 20:04 |
SimEmu 6.01 bug or my problem? | martina | Sim Cloning and Scaning | 6 | 10-21-2003 07:36 |
