02-26-2010, 01:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 367030 Status: Offline Thanks Meter: 16 | 5220 SECURITY_TEST failed! and npc missing SW Version: V 05.63 12-01-09 RM-411 (c) Nokia Imei plain: 35684002869160-7 Product Code: 0563611 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356840028691607 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF sd repair Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05.63 12-01-09 RM-411 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 5.219 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-411_356840028691607_SD.RPL" missing NPC data. Certificate programmed successfully ! pm auth Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05.63 12-01-09 RM-411 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 5.219 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-411_356840028691607_SD.RPL" missing NPC data. Certificate programmed successfully ! Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 112.200.182.255 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request good am guys.... how can i fix this problem 5220 contact service.... |
02-26-2010, 01:48 | #3 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 922938 Status: Offline Thanks Meter: 59 | yeah! 1st: sx4 authenticate 2nd: write pm full modified form 1 to 309 3rd: then hit sd wait and see... |
The Following User Says Thank You to gsmTECHNICIAN For This Useful Post: |
02-26-2010, 02:00 | #4 (permalink) |
Member: 367030 Status: Offline Thanks Meter: 16 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05.63 12-01-09 RM-411 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... i try load pm 1 and 309 then write no luck... super sd auth no luck and i try again pm auth.. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05.63 12-01-09 RM-411 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 112.200.182.255 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-26-2010, 02:04 | #6 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | only write CCC_DATA HWC_DATA or backup your rpl and then edit your rpl copy paste CCC_DATA HWC_DATA a the same phone from good phone... good luck |
The Following User Says Thank You to aswancamel For This Useful Post: |
02-26-2010, 02:16 | #9 (permalink) | |
Member: 367030 Status: Offline Thanks Meter: 16 | Quote:
sir this is may bck up rpl RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 16200015E1817D5640CAAE77C36365087F460A56 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x160 bytes). Reading RAP HWC (0xD4 bytes). Flash Imei: 35684002869160 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35684002869160_BA CK.rpl" http://rapidshare.com/files/35593586...30666594396621 i dont have same phone sir , can u do this for me if u have same phone or back up...ty | |
02-26-2010, 02:28 | #10 (permalink) |
Insane Poster Join Date: Mar 2007
Member: 469296 Status: Offline Thanks Meter: 12 | try these. use hwk ; backup all necessary>sx4b>write pm from other phone but same type>write all rpl data without npc 5220 from other phone>write npc>info>look at the window.... use mx key : bush check.....go to repar super sd auth n pm auth....goodluck |
The Following User Says Thank You to bukitmascell For This Useful Post: |
6301 scurity test failed with NPC certificate without npc ok | tiger43 | Nokia Base Band 5 ( BB-5 ) | 13 | 03-19-2010 09:23 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
5220 took logs but still says SECURITY_TEST failed! | hasnain | Universalbox | 14 | 01-22-2010 18:22 |
