Old 02-26-2010, 01:44   #1 (permalink)
Member: 367030
Thanks Meter: 16
Exclamation 5220 SECURITY_TEST failed! and npc missing
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 05.63 12-01-09 RM-411 (c) Nokia
Imei plain: 35684002869160-7
Product Code: 0563611
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 356840028691607
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
sd repair
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 05.63 12-01-09 RM-411 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 5.219 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-411_356840028691607_SD.RPL"
missing NPC data.
Certificate programmed successfully !
pm auth
missing NPC data.
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 112.200.182.255
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
good am guys.... how can i fix this problem 5220 contact service....
Old 02-26-2010, 01:45   #2 (permalink)
Member: 507861
Thanks Meter: 69
try super st auth then write pm field1 and 309
The Following User Says Thank You to ELOY1024 For This Useful Post:
Old 02-26-2010, 01:48   #3 (permalink)
gsmTECHNICIAN's Avatar
Member: 922938
Thanks Meter: 59
yeah!
1st: sx4 authenticate
2nd: write pm full modified form 1 to 309
3rd: then hit sd
wait and see...
The Following User Says Thank You to gsmTECHNICIAN For This Useful Post:
Old 02-26-2010, 02:00   #4 (permalink)
Member: 367030
Thanks Meter: 16
Restarting phone ...
i try load pm 1 and 309 then write no luck... super sd auth no luck and i try again pm auth..
No SX4 Card found.
Old 02-26-2010, 02:02   #5 (permalink)
Member: 507861
Thanks Meter: 69
try super sd auth then write pm..not sx4 auth
Old 02-26-2010, 02:04   #6 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
only write
CCC_DATA
HWC_DATA
or backup your rpl and then edit your rpl
copy paste
CCC_DATA
HWC_DATA
a the same phone from good phone...
good luck
The Following User Says Thank You to aswancamel For This Useful Post:
Old 02-26-2010, 02:06   #7 (permalink)
Member: 367030
Thanks Meter: 16
no luck sir.............
The Following User Says Thank You to dickies22 For This Useful Post:
Old 02-26-2010, 02:15   #8 (permalink)
Member: 469296
Thanks Meter: 12
no luck... what....
can u post here super sd auth process?
Old 02-26-2010, 02:16   #9 (permalink)
Member: 367030
Thanks Meter: 16
Originally Posted by aswancamel View Post
only write
CCC_DATA
HWC_DATA
copy paste
CCC_DATA
HWC_DATA
good luck
sir this is may bck up rpl
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 16200015E1817D5640CAAE77C36365087F460A56
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35684002869160
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35684002869160_BA CK.rpl"
http://rapidshare.com/files/35593586...30666594396621
i dont have same phone sir , can u do this for me if u have same phone or back up...ty
Old 02-26-2010, 02:28   #10 (permalink)
Member: 469296
Thanks Meter: 12
try these.
use hwk ; backup all necessary>sx4b>write pm from other phone but same type>write all rpl data without npc 5220 from other phone>write npc>info>look at the window....
use mx key : bush check.....go to repar super sd auth n pm auth....goodluck
The Following User Says Thank You to bukitmascell For This Useful Post:
Old 02-26-2010, 02:40   #11 (permalink)
Member: 757799
Thanks Meter: 782
do 1 to 4 procedure
http://forum.gsmhosting.com/vbb/show...36&postcount=1
The Following User Says Thank You to trio1 For This Useful Post:
Old 02-26-2010, 02:50   #12 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
wait a second, i will try
Old 02-26-2010, 03:00   #13 (permalink)
Member: 367030
Thanks Meter: 16
ok sir thnk you very much sir....
Old 02-26-2010, 03:03   #14 (permalink)
Member: 367030
Thanks Meter: 16
other link sir
http://uploadmb.com/dw.php?id=126714...69160_BACK.rpl
Old 02-26-2010, 03:03   #15 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
get it here
http://www.4shared.com/file/22994581...9160_BACK.html
6301 scurity test failed with NPC certificate without npc ok tiger43 Nokia Base Band 5 ( BB-5 ) 13 03-19-2010 09:23
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-03-2010 15:58
5220 took logs but still says SECURITY_TEST failed! hasnain Universalbox 14 01-22-2010 18:22
Page generated in 0.28221 seconds with 9 queries
