12-20-2009, 09:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | With Jaf Dead But With Mx-Key Ok Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11446, Date: 25-11-2009 Processing file: rm392__04.56.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 11.75 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009B3B88:3B8ADA60 Area [01000000-0101FFFF] erased in 1.156 s Area [01020000-01CFFFFF] erased in 2 min 2.703 s Flash programming ... Programming completed in 1 min 19.812 s File Processed in 3 min 38.062 s Processing file: rm392__04.56.image_el as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.50 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009B3B88:C5A4DA78 Area [02180000-02E7FFFF] erased in 2 min 0.125 s Area [02E80000-02FBFFFF] erased in 11.734 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 29.360 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.062 s File Processed in 3 min 9.156 s Processing file: rm392__04.56.ppm_el as PPM [DCT4,DCT4 ALGORITHM] size: 2.08 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH - COMBO FLASH - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009B3B88:2984DA60 Area [01D00000-0217FFFF] erased in 42.531 s Flash programming ... Programming completed in 15.140 s File Processed in 1 min 10.672 s Flashing completed in 7 min 58.109 s After Flash Processing ... Reseting Factory Values OK. PhoneType:RM-392 SwVersion: V 04.56 02-07-08 RM-392 (c) Nokia MCU file: rm392__04.56.mcusw Trying to find patch position ...OK, case id: 4 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009B3B88:3B8ADA60 Area [01000000-0101FFFF] erased in 1.125 s Area [01080000-0109FFFF] erased in 1.171 s Area [01BC0000-01BDFFFF] erased in 1.375 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009B3B88:3B8ADA60 Area [01000000-0101FFFF] erased in 1.266 s Area [01080000-0109FFFF] erased in 1.219 s Programming ... Programming completed. Completed in 1 min 24.094 s Phone Type: RM-392 (Nokia 2680s-2) SW Version: V 04.56 02-07-08 RM-392 (c) Nokia Imei plain: 35639002941944-2 Imei OTP: 35639002941944 Product Code: 0564367 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: EL Language Pack: - not available. Imei net: 35639002941944 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 9 min 46.828 s Writing PM from Node ... Section: 1 - Key: 0, size 120 bytes written. - Key: 2, size 90 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 90 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 2 bytes written. Section: 2 - Key: 0, size 440 bytes written. Section: 4 - Key: 1, size 16 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 16, size 4 bytes written. - Key: 17 skipped - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 7 - Key: 0, size 4 bytes written. - Key: 1, size 32 bytes written. - Key: 2, size 4 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 8 bytes written. - 120 skipped Completed in 9.734 s Imei net: 35639002941944 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 6.500 s |
The Following User Says Thank You to alamgarh For This Useful Post: |
12-20-2009, 12:37 | #3 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | Code:
and also there are phone that can be done with MXkey that cannot be revived in JAF........ because yesterday i'ved encountered a 6120c autoshut off problem..... and..... i flashed it into MXkey but the result is only nokia......hang........ then i tried flashing it to JAF and the result is done without any error...... Last edited by =Deftones=; 12-20-2009 at 12:42. | |
12-20-2009, 12:40 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | Quote:
Yes it is. One thing is quite clear to all of us that no tool is complete and perfect and every tool has its own features. | |
The Following User Says Thank You to pallumobile For This Useful Post: |
UnikGSM.com Now Launched! JAF Cables £1.49 MX Key £27.99 + MORE Amazing Offers! | UnikGSM | Main Sales Section | 0 | 02-19-2010 13:36 |
JAF-PKEY reader and MX-KEY Card | d@le | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-06-2010 18:26 |
can i use JAF Pkey reader for MX key card? | Cake | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-03-2010 19:17 |
