Old 09-30-2009, 05:17   #1 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
5220; simlock data corrupted; is it possible to be repaired w/o ask2rpl?
Hello,
got 5220 rm-411, contact service
damaged in security n simlock..
security area has been repaired, and is OK. one problem left, and that's its simlock
here's the log when i did BUS check
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 0510010D8D9F02542966F8D924B3F95DEC13E515
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Original Imei: 35366201010036
Original Product code: 0563666
Bluetooth ID: 0021ABE46B60
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 04.86 08-08-08 RM-411 (c) Nokia
Imei plain: 35366201010036-0
Product Code: 0563666
VariantId: X
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
Avoid manual erase to this phone !
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
TimeStamp: 2008-07-01T12:19:35Z
SW Version: 04.00
Variant Version: 001
ProductProfile: RM411_0563666_04.00_001.spr
Simlock: 0563666_simlock.bin
SIMLOCK_DATA corrupted!
and this is log after security (pm area 1 n 308) repaired
VariantId: X
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST passed
SW Version: 04.00
tried already repairing simlock data using MX-key (option: repair SL; ticked PA_SL2; on tab imei and security), but no luck
here's the log
Backup already exist.
Error: Security block invalid or PM corrupted !
is there any other way to repair/ solve this problem w/o ask new rpl?
The Following User Says Thank You to ru_dee For This Useful Post:
Old 09-30-2009, 06:09   #2 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
pm n imei back-up were conducted after CS, i think it won't help -FYI the phone is PA_SL2, got pm308 protected-
restoring pm n imei back-up, then, will damage superdongle, and causing wd timer active
Old 09-30-2009, 07:02   #3 (permalink)
neo_2005's Avatar
Member: 65656
Thanks Meter: 91
with other version not protected SD
Old 09-30-2009, 07:05   #4 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
u mean phone sw version or mobileX version?
Old 09-30-2009, 20:06   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
flash with unprotected frimware ,
and restore your backup .
br,
Old 10-01-2009, 03:12   #6 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
br,
unprotected firmware? u mean flashing with other type/model firmware like rm-303, let's say v.7.0?
or else?
Old 10-01-2009, 03:21   #7 (permalink)
JHUNpanabO's Avatar
Member: 265729
Thanks Meter: 144
flash your phone another version....
Old 10-01-2009, 03:33   #8 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
upgraded already to firmware v.05.63, and didn't solve anything
Old 10-01-2009, 03:48   #9 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
i flashed using rm-303 v.08.32, rpl n pm backed-up already.
i did full-erase, ticking safe erase, and automatically back-up rpl if possible, here's log
Rpl backup already exist.
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 63.75 MB
CMT NOR area [00000000-03FBFFFF] erased in 3 min 16.094 s
flashed w/ rm-303 firmware; mcu n ppm only
Processing file: rm303__08.32.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 17.05 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
RAP PAPUBKEYS is blank/erased.
Total erase size: 18.00 MB
CMT NOR area [00000000-000006BF] erased in 0.063 s
CMT NOR area [000006C0-0001FFFF] erased in 0.078 s
CMT NOR area [00040000-000BFFFF] erased in 0.156 s
CMT NOR area [000C0000-0013FFFF] erased in 0.156 s
CMT NOR area [00140000-010DFFFF] erased in 3.609 s
CMT NOR area [010E0000-0121FFFF] erased in 0.312 s
Flash programming ...
Selecting first PAPUB block with matching CMT RootKey
CMT PAPUBKEYS, RAP Certificate 90 v1 written.
Programming completed in 1 min 52.078 s
Processing file: rm303__08.32.ppm_t as PPM
 [BB5,BB5 ALGORITHM]  size: 6.05 MB
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
Total erase size: 6.50 MB
CMT NOR area [01220000-0189FFFF] erased in 1.531 s
Programming completed in 38.453 s
Flashing completed in 3 min 21.579 s
Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 08.32 23-07-08 RM-303 (c) Nokia
Imei plain: 12345610654321-?
VariantId: T
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Imei plain is invalid !!!
Total time to process is 3 min 31.078 s
it successed turning simlock test from 'failed' to 'pass'
and warning 'pm 308 protected and not restorable' dissappear.
but when i restore pm n rpl backed-up, phone won't enter local mode
here's log
restoring pm
SIMLOCK invalid!
SIMLOCK_TEST passed
Phone authenticated to SUPERDONGLE already.
Writing PM from Node ...
Section: 1
 - Key: 0, size 12 bytes written.
 - Key: 2, size 70 bytes written.
 - Key: 3, size 70 bytes written.
 - Key: 4, size 70 bytes written.
 - Key: 6, size 276 bytes written.
 - Key: 7, size 276 bytes written.
 - Key: 8, size 276 bytes written.
 - Key: 10, size 384 bytes written.
 - Key: 11, size 384 bytes written.
 - Key: 12, size 384 bytes written.
 - Key: 14, size 384 bytes written.
 - Key: 15, size 384 bytes written.
 - Key: 16, size 384 bytes written.
 - Key: 17, size 32 bytes written.
 - Key: 19, size 16 bytes written.
Section: 2
 - Key: 0, size 440 bytes written.
Section: 4
 - Key: 1, size 800 bytes written.
 - Key: 3, size 10 bytes written.
 - Key: 4, size 8 bytes written.
 - Key: 5, size 8 bytes written.
 - Key: 6, size 8 bytes written.
 - Key: 9, size 5 bytes written.
 - Key: 18, size 80 bytes written.
 - Key: 19, size 4 bytes written.
 - Key: 28, size 2 bytes written.
Section: 8
 - Key: 0, size 2 bytes written.
 - Key: 1, size 16 bytes written.
 - Key: 2, size 16 bytes written.
 - Key: 3, size 128 bytes written.
 - Key: 4, size 128 bytes written.
 - Key: 8, size 8 bytes written.
 - Key: 9, size 8 bytes written.
Warning: failed to write 8 - 10 (24 bytes)
Section: 11
 - Key: 0, size 4 bytes written.
 - Key: 1, size 4 bytes written.
 - Key: 2, size 4 bytes written.
 - Key: 3, size 4 bytes written.
 - Key: 5, size 6 bytes written.
 - Key: 6, size 2 bytes written.
 - Key: 14, size 2 bytes written.
 - Key: 15, size 2 bytes written.
 - Key: 16, size 2 bytes written.
 - Key: 17, size 2 bytes written.
 - Key: 18, size 16 bytes written.
 - Key: 19, size 32 bytes written.
 - Key: 20, size 32 bytes written.
 - Key: 21, size 2 bytes written.
 - Key: 22, size 2 bytes written.
 - Key: 23, size 2 bytes written.
 - Key: 24, size 2 bytes written.
 - Key: 25, size 2 bytes written.
 - Key: 26, size 2 bytes written.
 - Key: 27, size 2 bytes written.
 - Key: 29, size 2 bytes written.
 - Key: 30, size 2 bytes written.
 - Key: 31, size 2 bytes written.
 - Key: 32, size 2 bytes written.
 - Key: 33, size 2 bytes written.
 - Key: 34, size 2 bytes written.
 - Key: 35, size 2 bytes written.
 - Key: 36, size 2 bytes written.
 - Key: 37, size 2 bytes written.
 - Key: 38, size 2 bytes written.
 - Key: 39, size 2 bytes written.
 - Key: 40, size 2 bytes written.
 - Key: 41, size 2 bytes written.
 - Key: 42, size 2 bytes written.
 - Key: 43, size 2 bytes written.
 - Key: 44, size 2 bytes written.
 - Key: 45, size 2 bytes written.
 - Key: 46, size 2 bytes written.
 - Key: 47, size 2 bytes written.
 - Key: 48, size 2 bytes written.
 - Key: 49, size 2 bytes written.
 - Key: 50, size 2 bytes written.
 - Key: 51, size 2 bytes written.
 - Key: 52, size 2 bytes written.
 - Key: 53, size 2 bytes written.
 - Key: 54, size 2 bytes written.
 - Key: 55, size 2 bytes written.
 - Key: 56, size 2 bytes written.
 - Key: 57, size 2 bytes written.
 - Key: 58, size 2 bytes written.
 - Key: 59, size 2 bytes written.
 - Key: 60, size 2 bytes written.
 - Key: 61, size 2 bytes written.
 - Key: 62, size 2 bytes written.
 - Key: 63, size 2 bytes written.
 - Key: 64, size 2 bytes written.
 - Key: 65, size 2 bytes written.
 - Key: 66, size 4 bytes written.
 - Key: 68, size 4 bytes written.
 - Key: 69, size 4 bytes written.
 - Key: 70, size 4 bytes written.
 - Key: 71, size 4 bytes written.
 - Key: 72, size 16 bytes written.
 - Key: 73, size 4 bytes written.
 - Key: 74, size 2 bytes written.
 - Key: 75, size 13 bytes written.
Section: 12
 - Key: 0, size 102 bytes written.
Section: 13
 - Key: 1, size 2 bytes written.
 - Key: 3, size 2 bytes written.
 - Key: 8, size 2 bytes written.
 - Key: 11, size 48 bytes written.
 - Key: 12, size 4 bytes written.
 - Key: 15, size 886 bytes written.
 - Key: 19, size 8 bytes written.
 - Key: 37, size 4 bytes written.
 - Key: 42, size 4 bytes written.
 - Key: 43, size 4 bytes written.
 - Key: 45, size 4 bytes written.
 - Key: 46, size 4 bytes written.
 - Key: 48, size 4 bytes written.
 - Key: 53, size 4 bytes written.
 - Key: 54, size 4 bytes written.
 - Key: 60, size 4 bytes written.
 - Key: 61, size 4 bytes written.
 - Key: 63, size 4 bytes written.
 - Key: 64, size 4 bytes written.
 - Key: 67, size 4 bytes written.
 - Key: 72, size 4 bytes written.
 - Key: 74, size 4 bytes written.
 - Key: 75, size 2 bytes written.
 - Key: 76, size 2 bytes written.
 - Key: 77, size 2 bytes written.
 - Key: 83, size 2 bytes written.
 - Key: 85, size 4 bytes written.
 - Key: 86, size 4 bytes written.
 - Key: 87, size 2 bytes written.
 - Key: 89, size 4 bytes written.
 - Key: 90, size 4 bytes written.
 - Key: 91, size 2 bytes written.
 - Key: 93, size 4 bytes written.
 - Key: 94, size 4 bytes written.
 - Key: 95, size 2 bytes written.
 - Key: 97, size 4 bytes written.
 - Key: 98, size 4 bytes written.
 - Key: 99, size 2 bytes written.
 - Key: 100, size 4 bytes written.
 - Key: 101, size 2 bytes written.
 - Key: 103, size 4 bytes written.
 - Key: 104, size 4 bytes written.
 - Key: 105, size 4 bytes written.
 - Key: 106, size 4 bytes written.
 - Key: 107, size 4 bytes written.
 - Key: 108, size 2 bytes written.
 - Key: 109, size 4 bytes written.
 - Key: 110, size 4 bytes written.
 - Key: 111, size 4 bytes written.
 - Key: 112, size 2 bytes written.
 - Key: 113, size 4 bytes written.
 - Key: 114, size 4 bytes written.
 - Key: 118, size 4 bytes written.
 - Key: 119, size 4 bytes written.
 - Key: 123, size 8 bytes written.
 - Key: 129, size 4 bytes written.
 - Key: 130, size 4 bytes written.
 - Key: 133, size 2 bytes written.
 - Key: 135, size 2 bytes written.
 - Key: 138, size 4 bytes written.
 - Key: 139, size 4 bytes written.
 - Key: 144, size 4 bytes written.
 - Key: 145, size 8 bytes written.
 - Key: 146, size 4 bytes written.
 - Key: 147, size 4 bytes written.
 - Key: 159, size 2 bytes written.
 - Key: 160, size 2 bytes written.
 - Key: 167, size 8 bytes written.
 - Key: 168, size 4 bytes written.
 - Key: 177, size 4 bytes written.
 - Key: 178, size 2 bytes written.
 - Key: 190, size 4 bytes written.
 - Key: 191, size 2 bytes written.
 - Key: 193, size 4 bytes written.
 - Key: 196, size 10 bytes written.
Section: 31
 - Key: 4, size 14 bytes written.
Section: 42
 - Key: 1, size 12 bytes written.
 - Key: 2, size 36 bytes written.
 - Key: 3, size 36 bytes written.
 - Key: 4, size 36 bytes written.
 - Key: 5, size 36 bytes written.
 - Key: 6, size 36 bytes written.
 - Key: 7, size 40 bytes written.
 - Key: 8, size 40 bytes written.
 - Key: 9, size 40 bytes written.
 - Key: 10, size 40 bytes written.
 - Key: 11, size 40 bytes written.
 - Key: 12, size 40 bytes written.
 - Key: 13, size 40 bytes written.
 - Key: 14, size 40 bytes written.
Section: 50
Section: 54
Section: 66
 - Key: 0, size 524 bytes written.
 - Key: 1, size 240 bytes written.
 - Key: 2, size 240 bytes written.
 - Key: 5, size 240 bytes written.
 - Key: 6, size 4 bytes written.
 - Key: 7, size 4 bytes written.
 - Key: 8, size 4 bytes written.
 - Key: 9, size 4 bytes written.
 - Key: 10, size 240 bytes written.
 - Key: 11, size 240 bytes written.
 - Key: 16, size 4 bytes written.
 - Key: 18, size 4 bytes written.
 - Key: 20, size 4 bytes written.
 - Key: 22, size 4 bytes written.
 - Key: 24, size 4 bytes written.
 - Key: 26, size 4 bytes written.
 - Key: 28, size 4 bytes written.
 - Key: 30, size 4 bytes written.
 - Key: 32, size 4 bytes written.
 - Key: 34, size 4 bytes written.
 - Key: 38, size 4 bytes written.
 - Key: 101, size 4 bytes written.
 - Key: 108, size 4 bytes written.
 - Key: 133, size 7 bytes written.
 - Key: 134, size 7 bytes written.
 - Key: 135, size 7 bytes written.
Section: 96
Section: 107
 - Key: 0, size 21 bytes written.
 - Key: 1, size 89 bytes written.
 - Key: 2, size 69 bytes written.
 - Key: 25, size 132 bytes written.
 - Key: 26, size 12 bytes written.
Section: 116
 - Key: 15, size 40 bytes written.
 - Key: 16, size 40 bytes written.
Section: 120
 - Key: 0, size 944 bytes written.
 - Key: 1, size 80 bytes written.
 - Key: 2, size 20 bytes written.
 - Key: 3, size 112 bytes written.
Section: 153
 - Key: 0, size 68 bytes written.
 - Key: 1, size 68 bytes written.
 - Key: 2, size 68 bytes written.
 - Key: 3, size 68 bytes written.
 - Key: 4, size 68 bytes written.
 - Key: 5, size 68 bytes written.
Section: 193
 - Key: 2, size 8 bytes written.
 - Key: 3, size 32 bytes written.
 - Key: 4, size 32 bytes written.
 - Key: 9, size 64 bytes written.
Section: 217
 - Key: 0, size 32 bytes written.
Section: 218
Section: 301
Section: 308
Warning: failed to write 308 - 1 (8192 bytes)
Warning: failed to write 308 - 5 (10 bytes)
Section: 309
 - Key: 2, size 12 bytes written.
 - Key: 4, size 12 bytes written.
 - Key: 5, size 12 bytes written.
 - Key: 7, size 12 bytes written.
 - Key: 8, size 12 bytes written.
 - Key: 17, size 12 bytes written.
 - Key: 22, size 12 bytes written.
Section: 322
Section: 341
 - Key: 4, size 4418 bytes written.
Section: 354
 - Key: 0, size 3 bytes written.
Section: 355
 - Key: 1, size 2028 bytes written.
Section: 356
Section: 362
 - Key: 1, size 120 bytes written.
Completed in 1 min 1.188 s
restoring rpl
Updating PRODUCTCODE (0563666)... OK
Updating PSN (DTB727192)... OK
Updating HWID (1000)... OK
Updating SIMLOCK...OK
Updating SIMLOCK_KEY...error 0x1
Updating SUPERDONGLE_KEY from backup ...OK
Updating WMDRM_PD...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
PAPUBKEYS from phone is NOT same as on certificate, rpl does not seems to be valid for this phone. Do you want to continue? pressed 'yes'
NPC verify error, RAP PAPUPKEYS not match or empty!
Updating CMT  NPC ...OK
Updating CMT  CCC ...OK
Updating CMT  HWC ...OK
Certificate programmed successfully !
any idea what to do next?
Old 10-01-2009, 21:24   #10 (permalink)
Member: 310458
Thanks Meter: 94
SIMLOCK invalid!  <<< maybe its mean empty
SIMLOCK_TEST passed
if simlock invalid ,can not repair with this method (currently still have to calculate RPL)
SIMLOCK seems to be valid
if simlock valid and simlock test failed, you can do repair with this method
CMIIW
The Following User Says Thank You to utuh For This Useful Post:
Old 10-02-2009, 06:00   #11 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
SIMLOCK_TEST passed
CMIIW
thank u Sir, that's what i've been searching, then there's no sucha trick/way yet, to solve this problem w/o ask2rpl
there's way to fix 'simlock invalid' using other tools, but only for rapido cpu, isn't it?
Old 10-08-2009, 09:16   #12 (permalink)
Registered User
Member: 34599
Thanks Meter: 12
ny body can help me plz...urgent.i have 5220(rm-411)contact service.can solved without rpl??any body have solution plz...
this log
SW Version: V 06.51 23-03-09 RM-411 (c) Nokia
Imei plain: 35366201517644-9
Product Code: 0563611
VariantId: X
Language Pack:
- not available.
SUPERDONGLE_KEY invalid!
WD timer enabled, phone will reboot itself after 3 min.
and this is backup
Old 10-08-2009, 09:27   #13 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
this log
VariantId: X
Language Pack:
- not available.
and this is backup
It looks SUPERDONGLE_KEY invalid!.I think no way to revive it without new rpl.Actualy no device can back up SUPERDONGLE_KEY data yet.
Old 10-08-2009, 11:12   #14 (permalink)
Member: 1086393
Thanks Meter: 771
br,
Unprotected firmware? what it means sir?
Is it possible to gdfs repair w200i with SE Ultimatr Unlocker, tuhingr Cruiser Suite 2 09-26-2008 09:13
is it possible to download ring tones on a800 with data cable acronus Samsung Media, Games, Ringtones 5 02-07-2006 06:09
Benq A500. Is it possible to be unlocked ? doctormike FuriouS II 0 08-18-2005 20:01
Is it possible to be from a battery? stefanovmm Hardware Repair by brands 6 11-30-2004 03:57
Is it possible to remove SIMLOCK on NEC DB 2000? Bogi Various 0 06-23-2002 17:36
Page generated in 0.33409 seconds with 10 queries
