09-30-2009, 05:17 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | 5220; simlock data corrupted; is it possible to be repaired w/o ask2rpl? got 5220 rm-411, contact service damaged in security n simlock.. security area has been repaired, and is OK. one problem left, and that's its simlock here's the log when i did BUS check Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0510010D8D9F02542966F8D924B3F95DEC13E515 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B Original Imei: 35366201010036 Original Product code: 0563666 Bluetooth ID: 0021ABE46B60 Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 04.86 08-08-08 RM-411 (c) Nokia Imei plain: 35366201010036-0 Product Code: 0563666 VariantId: X Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. Avoid manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! TimeStamp: 2008-07-01T12:19:35Z SW Version: 04.00 Variant Version: 001 ProductProfile: RM411_0563666_04.00_001.spr Simlock: 0563666_simlock.bin SIMLOCK_DATA corrupted! Code: Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 04.86 08-08-08 RM-411 (c) Nokia Imei plain: 35366201010036-0 Product Code: 0563666 VariantId: X Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. Avoid manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed TimeStamp: 2008-07-01T12:19:35Z SW Version: 04.00 Variant Version: 001 ProductProfile: RM411_0563666_04.00_001.spr Simlock: 0563666_simlock.bin SIMLOCK_DATA corrupted! here's the log Code: SIMLOCK_DATA corrupted! Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Error: Security block invalid or PM corrupted ! |
The Following User Says Thank You to ru_dee For This Useful Post: |
09-30-2009, 06:09 | #2 (permalink) |
Member: 911645 Status: Offline Thanks Meter: 19 | pm n imei back-up were conducted after CS, i think it won't help -FYI the phone is PA_SL2, got pm308 protected- restoring pm n imei back-up, then, will damage superdongle, and causing wd timer active |
10-01-2009, 03:48 | #9 (permalink) |
Member: 911645 Status: Offline Thanks Meter: 19 | i flashed using rm-303 v.08.32, rpl n pm backed-up already. i did full-erase, ticking safe erase, and automatically back-up rpl if possible, here's log Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Rpl backup already exist. RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0510010D8D9F02542966F8D924B3F95DEC13E515 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B Total erase size: 63.75 MB CMT NOR area [00000000-03FBFFFF] erased in 3 min 16.094 s Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Processing file: rm303__08.32.mcusw as MCU [BB5,BB5 ALGORITHM] size: 17.05 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0510010D8D9F02542966F8D924B3F95DEC13E515 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Total erase size: 18.00 MB CMT NOR area [00000000-000006BF] erased in 0.063 s CMT NOR area [000006C0-0001FFFF] erased in 0.078 s CMT NOR area [00040000-000BFFFF] erased in 0.156 s CMT NOR area [000C0000-0013FFFF] erased in 0.156 s CMT NOR area [00140000-010DFFFF] erased in 3.609 s CMT NOR area [010E0000-0121FFFF] erased in 0.312 s Flash programming ... Selecting first PAPUB block with matching CMT RootKey CMT PAPUBKEYS, RAP Certificate 90 v1 written. Programming completed in 1 min 52.078 s Processing file: rm303__08.32.ppm_t as PPM [BB5,BB5 ALGORITHM] size: 6.05 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0510010D8D9F02542966F8D924B3F95DEC13E515 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Total erase size: 6.50 MB CMT NOR area [01220000-0189FFFF] erased in 1.531 s Flash programming ... Programming completed in 38.453 s Flashing completed in 3 min 21.579 s Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 08.32 23-07-08 RM-303 (c) Nokia Imei plain: 12345610654321-? Product Code: 0563666 VariantId: T Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! Total time to process is 3 min 31.078 s and warning 'pm 308 protected and not restorable' dissappear. but when i restore pm n rpl backed-up, phone won't enter local mode here's log Code: restoring pm SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 276 bytes written. - Key: 8, size 276 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 12, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 15, size 384 bytes written. - Key: 16, size 384 bytes written. - Key: 17, size 32 bytes written. - Key: 19, size 16 bytes written. Section: 2 - Key: 0, size 440 bytes written. Section: 4 - Key: 1, size 800 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. Warning: failed to write 8 - 10 (24 bytes) Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 2 bytes written. - Key: 64, size 2 bytes written. - Key: 65, size 2 bytes written. - Key: 66, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 16 bytes written. - Key: 73, size 4 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 1, size 2 bytes written. - Key: 3, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 19, size 8 bytes written. - Key: 25, size 2 bytes written. - Key: 37, size 4 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 48, size 4 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 58, size 2 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 123, size 8 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 133, size 2 bytes written. - Key: 135, size 2 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 177, size 4 bytes written. - Key: 178, size 2 bytes written. - Key: 190, size 4 bytes written. - Key: 191, size 2 bytes written. - Key: 193, size 4 bytes written. - Key: 196, size 10 bytes written. Section: 31 - Key: 4, size 14 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 66 - Key: 0, size 524 bytes written. - Key: 1, size 240 bytes written. - Key: 2, size 240 bytes written. - Key: 5, size 240 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 240 bytes written. - Key: 16, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 108, size 4 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 133, size 7 bytes written. - Key: 134, size 7 bytes written. - Key: 135, size 7 bytes written. Section: 96 - Key: 0, size 2 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 120 - Key: 0, size 944 bytes written. - Key: 1, size 80 bytes written. - Key: 2, size 20 bytes written. - Key: 3, size 112 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 308 Warning: failed to write 308 - 1 (8192 bytes) Warning: failed to write 308 - 5 (10 bytes) - Key: 9, size 40 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Section: 322 Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4418 bytes written. Section: 354 - Key: 0, size 3 bytes written. Section: 355 - Key: 1, size 2028 bytes written. Section: 356 - Key: 0, size 2 bytes written. Section: 362 - Key: 1, size 120 bytes written. Completed in 1 min 1.188 s ================================== restoring rpl Imei: 35366201010036 Updating PRODUCTCODE (0563666)... OK Updating PSN (DTB727192)... OK Updating HWID (1000)... OK Updating SIMLOCK...OK Updating SIMLOCK_KEY...error 0x1 Updating SUPERDONGLE_KEY from backup ...OK Updating WMDRM_PD...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0510010D8D9F02542966F8D924B3F95DEC13E515 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D ---- PAPUBKEYS from phone is NOT same as on certificate, rpl does not seems to be valid for this phone. Do you want to continue? pressed 'yes' ---- NPC verify error, RAP PAPUPKEYS not match or empty! Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! PAPUBKEYS from phone is NOT same as on certificate, rpl does not seems to be valid for this phone. Do you want to continue? |
10-01-2009, 21:24 | #10 (permalink) |
Freak Poster Join Date: Jul 2006 Location: indonesia
Member: 310458 Status: Offline Thanks Meter: 94 | Code: SIMLOCK invalid! <<< maybe its mean empty SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed SIMLOCK_DATA corrupted! Code: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! CMIIW |
The Following User Says Thank You to utuh For This Useful Post: |
10-02-2009, 06:00 | #11 (permalink) | |
Member: 911645 Status: Offline Thanks Meter: 19 | Quote:
there's way to fix 'simlock invalid' using other tools, but only for rapido cpu, isn't it? | |
10-08-2009, 09:16 | #12 (permalink) |
Registered User Join Date: Jul 2003 Age: 43
Member: 34599 Status: Offline Thanks Meter: 12 | ny body can help me plz...urgent.i have 5220(rm-411)contact service.can solved without rpl??any body have solution plz... this log Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 06.51 23-03-09 RM-411 (c) Nokia Imei plain: 35366201517644-9 Product Code: 0563611 VariantId: X Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. Avoid manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed and this is backup |
10-08-2009, 09:27 | #13 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Quote:
Is it possible to gdfs repair w200i with SE Ultimatr Unlocker, | tuhingr | Cruiser Suite | 2 | 09-26-2008 09:13 |
is it possible to download ring tones on a800 with data cable | acronus | Samsung Media, Games, Ringtones | 5 | 02-07-2006 06:09 |
Benq A500. Is it possible to be unlocked ? | doctormike | FuriouS II | 0 | 08-18-2005 20:01 |
Is it possible to be from a battery? | stefanovmm | Hardware Repair by brands | 6 | 11-30-2004 03:57 |
Is it possible to remove SIMLOCK on NEC DB 2000? | Bogi | Various | 0 | 06-23-2002 17:36 |
