05-16-2012, 11:58 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: gujarat ind
Member: 773986 Status: Offline Thanks Meter: 52 | 5230 rm-625 after no network Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000248E Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Processing MCU file: RM-625_51.1.002_prd.core.C00 [BB5,XSR 1.6] size: 95.97 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 14600019F08A0052C95F37329516405CC1BEBAA9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 42.721 s Processing PPM file: RM-625_51.1.002_prd.rofs2.V22 [BB5,XSR 1.6] size: 30.98 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 36.50 MB CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 54.194 s Processing PPM file: RM-625_51.1.002_C02_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.37 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 11.222 s Processing CNT file: RM625_51.1.002_000_001_U001.uda.fpsx [BB5,XSR 1.6] size: 17.07 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 31.104 s Total time for flashing process(boot+erase+write) was 4 min 37.648 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 214AA30B Verifying communication to device OK. Phone type: RM-625 (Nokia 5233) SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia ApeCoreSw: V 51.1.002 Imei plain: 35935103082414-2 Product code: 0585713 Battery voltage: 3842 mV, current: 322 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359351030824142 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
6150 Network problem, please HELP! | ZF | Nokia Hardware & Hardware Repair | 4 | 07-06-2004 18:07 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
