5233 onley vibret. 5233 use latest version after flash but onley vibret.use ENO file after flash but same. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: ******* Using device: HTI, FW ver: 00.24, SN: ******** Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14100004488C00528AB6B77DCC04BAB01B1DA374 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Processing MCU file: RM-625_51.9.002_prd.core.C00 [BB5,XSR 1.6] size: 95.02 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 33.266 s Processing PPM file: RM-625_51.9.002_prd.rofs2.V25 [BB5,XSR 1.6] size: 26.50 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 35.50 MB CMT FLASH,MuxOneNAND area [06DE0000-0915FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 19.031 s Processing PPM file: RM-625_51.9.002.549.04.rofs3.fpsx [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 18.563 s Processing CNT file: RM625_51.9.002_002_U549.uda.fpsx [BB5,XSR 1.6] size: 23.16 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 10.329 s Total time for flashing process(boot+erase+write) was 7 min 32.484 s |
1 Attachment(s) Quote:
use this but problem not solve. |
nokia c5 hi, i have nokia c5 rm645 by mistake i flashed with rm697 now phone is only vibrate.pls provide me any slution .how can i solve my problem pls....help.thanks |
or as a flasher by trying different usb |
