Old 02-03-2010, 13:25   #1 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Question 5300 super dongel error
After repair super dongel security test failed and not write pm .
Phone Type: RM-146 (Nokia 5300)
SW Version: V 07.20 23-10-08 RM-146 (c) Nokia.
Imei plain: 35483102106132-0
Product Code: 0538139
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 354831021061320
Version: SIMLOCK SERVER VERSION 63
Provider: Bharti Cellular Telecom Airtel, Country: India
Counter: 0/3, 0/10
CONFIG_DATA: 4041000000000000
PROFILE_BITS: 8000000000000006
BLOCK 1:   1=OPEN, DATA=40410F
BLOCK 2:   1=OPEN, DATA=40410F
BLOCK 3:   1=OPEN, DATA=00101F
Error on writing Pm
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.20 23-10-08 RM-146 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot  ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized :)!
warning: SD authorized but verify failed !
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (86 bytes)
Warning: failed to write 1 - 18 (86 bytes)
Warning: failed to write 1 - 20 (86 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 29 (6 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 0.500 s
Old 02-03-2010, 13:31   #2 (permalink)
Member: 1214789
Sonork: 32021919740206327
That SUPERDONGLE_KEY you are not good? SECURITY_TEST test fails, write a PM try?
Old 02-03-2010, 13:45   #3 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
You don't understd me.
I mean super sd auth not work for me after repair superdongel can't write pm.
Old 02-05-2010, 12:28   #4 (permalink)
Member: 518504
SUPERDONGLE_KEY repair is not working properly in MX Key
After repair SD "contact srvice" comes and PM 1 & 309 not Write
Please help
Old 02-05-2010, 12:36   #5 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
Write PM 1 to 309 with sx4
write rpl
Old 05-14-2010, 15:16   #6 (permalink)
experttelecom's Avatar
Member: 914898
Sonork: 100.1597109
Thanks Meter: 117
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Error on writing Pm
Section: 1
Section: 309
check on load rfbb from server then supersd auth write pm works perfectly....
br
experttelecom
5220 sim info invalid super dongel key repaired newtouch Universalbox 1 01-27-2010 14:35
sucsessfully super dongel data write in 6270 ranagaurav Universalbox 1 01-19-2010 15:14
secsussfully repaier super dongel key n72 ranagaurav Universalbox 3 01-17-2010 08:06
3110c after repair super dongel repair Hafiz ArslanAli Universalbox 8 01-15-2010 06:45
super dongel key corrupeted how to repair? neeraj1st MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-08-2010 09:07
Page generated in 0.18181 seconds with 9 queries
