11-17-2009, 16:06 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: 03453007200
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | 5320 contact retailer Version Info: MCU SW version: V ICPR71_09w12.1 31-03-09 RM-409 (c) Nokia HW version: 0210 RFIC version: 17141715 DSP version: ICPR71_09w10 APE SW Core version: 05.16 APE Variant version: 01.0105.16.C03.01 APE Test version: rm409_ENO_x_2.22v0.140 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Camera version: 992969737 Product Info: Production serial number: KCU109362 Product code: 0562156 Basic production code: 0560746 Long production SN: 0 Serial Numbers: IMEI plain: 3548260236xxxxx IMEI spare to net: 3A 45 28 06 32 46 05 02 IMEI SV to net: 33 45 28 06 32 46 05 32 F7 Other Info: Model : Nokia 5320 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII BSI: 3.4 KOhm Imei net: 3548260236xxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F while in self test its giving security test fail bt i tried pm also thnx in adv br Qaiser |
11-17-2009, 16:28 | #2 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 59732 Status: Offline Thanks Meter: 47 | Quote:
please write modified full pm with sx4 service problem 100% can be solved | |
11-17-2009, 16:55 | #3 (permalink) | |
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | Quote:
NK module version: 1.06 NK applet version: 00.20 You are connected using J.A.F interface Module activated with limited support! NK module ready. Please "Scan" or "BUS check" before any operation ... Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 119.153.151.36 SUPERDONGLE auth succeeded! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. - Key: 46, size 64 bytes written. Section: 2 - Key: 0, size 448 bytes written. Section: 4 - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 9, size 5 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 2 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 31 - Key: 4, size 14 bytes written. Section: 44 Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 79 bytes written. - Key: 2, size 79 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 42 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 16, size 40 bytes written. - 120 skipped Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 322 Section: 334 Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4516 bytes written. Section: 354 - Key: 0, size 13 bytes written. Completed in 4.563 s | |
11-17-2009, 17:40 | #5 (permalink) | |
RM-409 ( 5320 Xpres Music)_no 308.pm Phone Type: SW version: ID Test name Startup Result 88 TAHVOINT Y passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 93 SECURITY N !failed ! 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 56 SLEEPCLK_FREQ N passed 96 HOOKINT N passed 101 BTEMP N passed 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 85 CDSP_TX_IQ N !no signal 74 CDSP_TXC_DATA N !no signal 82 CDSP_PWR_DETECTOR_BIAS N !no signal 79 CDSP_RX_PLL_PHASE_LOCK N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 75 CDSP_WCDMA_TX_POWER N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal 7 KEYBOARD_STUCK N passed 21 LPRF_IF N passed 22 CAMERA_IF N passed 37 SEC_CAMERA_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 59 MAIN_LCD_IF N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 91 USB_LOOP N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) | |
11-19-2009, 12:13 | #7 (permalink) |
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | thi is the latest log Phone Type: RM-409 (Nokia 5320) SW Version: V ICPR71_09w12.1 31-03-09 RM-409 (c) Nokia Imei plain: 35482602364xxxx Product Code: 0562156 ApeCoreSw: 05.16 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! Imei net: 35482602364xxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
11-21-2009, 19:31 | #10 (permalink) |
Banned Join Date: Mar 2006
Member: 239004 Status: Offline Sonork: 100.1589817 Thanks Meter: 388 | mak backup full erse write rpl pm auth or sx4 and use felid 1 and 309 unlock and enjoy this methood also working with 6110 .. test 10000% working cradit goes to Rizwan jat |
The Following User Says Thank You to waqas_ali601200 For This Useful Post: |
5320 contact the retailer | dimitron | Cyclonebox | 2 | 01-27-2010 15:18 |
5320 contact retailer | ..::ApexComm::.. | HWK | 2 | 08-25-2009 08:19 |
ALL WD2 Contact Retailer "phone start up failed, contact retailer" problem | NokiaMobileCare | Nokia Hardware & Hardware Repair | 3 | 02-02-2009 05:12 |
6600 contact retailer ( i need to save contacts ) | CMV_2K | WD2 & APE (Symbian Phones) | 2 | 11-01-2004 08:43 |
