Old 07-30-2010, 18:50   #1 (permalink)
nura1335's Avatar
Member: 481744
Thanks Meter: 30
5130 contact service. pls help me
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 07.91 29-10-09 RM-495 (c) Nokia
Using cached productData[16D0010CD06F7F563EE2416EC6445C0C1C3E5B39] ...
Calculating SIMLOCK using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Completed in 5.421 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-495_3542????????_SIM.RPL"
Updating SIMLOCK...
error 0x1
Reading Simlock info ...
SIMLOCK_DATA corrupted!
Old 07-30-2010, 18:57   #2 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
it is SL3 ,no solution yet but if u have backup before makes contact service
just make rstore imi and will be ok
Old 07-30-2010, 18:59   #3 (permalink)
Member: 149942
Thanks Meter: 6
Yup...
it is SL3 no solution yet
Just wait....
Old 07-30-2010, 19:01   #4 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
with this we cant repaired yet
Old 07-30-2010, 19:01   #5 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
everyday we see here a lot of post about contact service.
first we need to know whats reasons for contact service
CONTACT SERVICE HAS SEVERAL REASON.LIKES....
1) RPL DAMAGED(IMEI 12345--------)
2)SIMLOCK DATA INVALID/CORUPTED
3)SECURITY TEST FAILED
4)HARDWARE
SOLUTION............
1)FOR RPL DAMAGED PHONE (IF U DONT HAVE BACKUP) U MUST BUY RPL.
2)FOR SIMLOCK DATA .IF UR PHONE SL1 AND SL2 U CAN EASILY REPAIR WITH MX-KEY.JUST TICK
!)REPAIR SIMLOCK
!!) MAKE SIMLOCK RPL
NOW PRESS REPAIR SIMLOCK.U WILL DONE. FOR SL3...NO SOLUTION YET.
3) FOR SECURITY TEST FAILED U NEED SUPER SD AUTH OR PMM AUTH AND WRITE
A MODIFIED PM.U WILL DONE.SL1.SL2.SL3.SUPPORTED.
REMEMBER,IF UR HWC AND CCC DATA EMTY UR PHONE SHOW SECURITY TEST FAILD ALSO
FOR CHECK HWC AND CCC DATA U JUST GO
SERVICE>PHONE TEST>VARIOUS>BB5 CERTIFICATE VALIDATION.
IF UR HWC AND CCC DATA IS EMPTY JUST PRESS RECOVER CERT.U WILL DONE
SO WHEN UR SET SECURITY TEST FAILED U MUST CHECK BB5 CERTIFICATE VALIDATION.
4) FOR HARDWARE ISSUE U NEED HARDWARE SOLUTION.
JUST ONE TIPS.
HOW CAN U SURE THIS IS HW PROBLEM??
IN MY EXPERIENCE,FIRST POWER ON PHONE WITHOUT SIM CARD.
IF UR PHONE DIRECT SHOW SONTACT SERVICE,THAN IT IS HW FAULT.
The Following User Says Thank You to MMDEBILI For This Useful Post:
Old 07-30-2010, 19:01   #6 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Updating SIMLOCK...
error 0x1
Have you ever heard the word SL3, if not read all the above sticky thread, 5130 is sl3, so not possible to repair ATM.
curvenger
Old 07-30-2010, 19:03   #7 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
Smile
Best of luck to all.
Old 07-30-2010, 19:30   #8 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
no any solution yet...................
Old 07-30-2010, 20:37   #9 (permalink)
nura1335's Avatar
Member: 481744
Thanks Meter: 30
I have Backup bet i am going to restore it is sowing this message
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 16D0010CD06F7F563EE2416EC6445C0C1C3E5B39
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0571584)... OK
Updating PSN (HEC345703)... OK
Updating HWID (1000)... OK
Updating LOCK ...error 0x0
Updating WMDRM_PD...OK
Certificate programmed successfully !
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35422303773515-6
Product Code: 0571584
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
Old 07-31-2010, 06:42   #10 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 1,005
Updating RF ...OK
Updating BB ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Language Pack:
- not available.
SIMLOCK invalid!
just wait few day .................................................. .......
Old 07-31-2010, 06:48   #11 (permalink)
Registered User
Member: 407063
Thanks Meter: 2,133
its SL3 model not solution this time i think u can only wait
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.25826 seconds with 9 queries
