Registered User
Member: 249276
Thanks Meter: 209 | 5530c SIMLOCK DATA (ANSWERED) Quote:
Version from phone: 40.0.003
Version from file: 40.0.003
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0846B00
Using device: HTI, FW ver: 00.24, SN: 00006B60
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35802203119020_BA CK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 21B00007727F00524E64AA9B6962F874B990AEBB
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
Processing MCU file: RM-504_40.0.003_prd.core.C00
[BB5,XSR 1.5] size: 105.24 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: F2B05364 [RAP Certificate 168 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 4 min 58.422 s
Processing PPM file: RM-504_40.0.003_prd.rofs2.V19
[BB5,XSR 1.5] size: 14.53 MB
Erase size: 32 MB
CMT FLASH,MuxOneNAND area [07360000-0935FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 42.688 s
Processing PPM file: RM-504_40.0.003_C02_prd.rofs3.fpsx
[BB5,XSR 1.5] size: 5.19 MB
Erase size: 11 MB
CMT FLASH,MuxOneNAND area [09360000-09E5FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 15.453 s
Processing CNT file: RM-504_32.0.007_007_000_U001.uda.fpsx
[BB5,XSR 1.5] size: 6.13 MB
Erase size: 88.75 MB
CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF]
NAND: OK
NAND: OK
Programming completed in 19.391 s
Total time for flashing process(boot+erase+write) was 6 min 27.328 s
Phone type: RM-504 (Nokia 5530 XpressMusic)
SW version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
Imei plain: 35802203119020-2
Product code: 0573246
Battery voltage: 4534 mV, current: 23 mA
ApeCoreSw: V 40.0.003
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid!
SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed!
SECURITY_TEST passed SIMLOCK_DATA corrupted!
SIMLOCK_DATA corrupted! | Help Mr. Manole the phone is white screen before flash what should I do for this problem?
Br,
Mister G |
