05-21-2011, 12:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | 5610 wrong flash help need !! after that security test failed then i did flashed with 359 firmware den shows Contact Service i did tried for repair lots of method but same result till now guys who can help me and i observed it may HWC CCC file problem, but i ddnt find rm-359 HWC CCC file so if any1 solved the issue,share it, it may helpful for mine. Code: Phone Type: RM-359 (Nokia 5610 XpressMusic) SW Version: V 08.23 21-11-08 RM-359 (c) Nokia Imei plain: 3529410******** Product Code: 0557826 Battery voltage: 4858 mV, current: 48 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3529410******* Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN 2.restored NPC backup only 3.repaired sd,and wrote full pm( 1-309 also tested) 4.repair sd, Code: TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes) Original Product Code: 0587489 Reading CMT VARIANT (0x0 bytes) Reading CMT CCC (0x160 bytes) Product Code: 0552212 Product Code missmatch ! Reading CMT HWC (0xD4 bytes) Product Code: 0552212 Product Code missmatch ! i tried recover cert from mxkey server but its shows error Code: Begin Certificate Request ... [InternalErrorFault] CERT [0587489] data not available for this phone (case id=0xCE01) |
05-25-2011, 08:50 | #2 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: nachna,jaisalmer[rajasthan] Age: 42
Member: 554531 Status: Offline Thanks Meter: 85 | Quote:
1. First of all u need good pm with SX4 ( do SX4/super SX4 after that pm1 and pm309 ) 2. if not solved than check CCC and HWC certificates How to repair CCC and HWC certificates ? backup RPL than open it in notepad there u will see NPC data after that CCC data and HWC data just replace CCC and HWC data with manoles uploaded clone RPLs ( of same model ) 3. if still not solved than recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON ) 4. if still same than Repair SL REPAIR SD SUPER SD AUTH write PM1 and PM309 5. if still same than make RPL backup full erase than flash than write rpl than Repair SL than SD repair than super AUTH than write PM . tested | |
05-25-2011, 10:22 | #4 (permalink) | |
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
thanks for ur reply but read above my post again ,, check wat i have done ! any way no need more reply i did gave phone to customer..! :P | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
