Old 03-10-2012, 10:42   #1 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
5610d contact service (ANSWERED)
dear sir , facind problem with contact service mobiles . i have green box and try to recove bb5 contact service with every possible comands but its after all it shows security test failed , please tell me step by step what to do or its not possible wiyh green box . i dont have atf box but at last i have to send mobile to my friend to do it in atf box . please help me ,
thnx
Old 03-10-2012, 10:49   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. you can do it with mxkey, so post buscheck logs.
Old 03-10-2012, 11:20   #3 (permalink)
Member: 573120
Thanks Meter: 145
this is the log bro
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB
TransmissionMode: DDR&TX2
Original Imei: 35865201595068
Original Product code: 0552249
Bluetooth ID: 001E3A73DC6C
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-242 (Nokia 5610d-1)
SW version: V 10.00 06-03-09 RM-242 (c) Nokia
Imei plain: 35865201595068-2
Battery voltage: 4670 mV, current: 130 mA
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358652015950682
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000006
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 03-10-2012, 11:26   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. in mxkey go to service>pm>click load pm from phone & click repair SD, click no if small window appears & your problem will be solve. have a good day.
Old 03-10-2012, 11:37   #5 (permalink)
Member: 573120
Thanks Meter: 145
its same bro . i do the same as u say but its again security test failed
please tel me step by step or bozz me at gaurav_qq in yahoo massenger , i ll give u my team id then you plz do u self if u have time ,
thnx in adv
Old 03-10-2012, 12:11   #6 (permalink)
Member: 573120
Thanks Meter: 145
can any one help me . sir manole is not responding
Old 03-10-2012, 12:39   #7 (permalink)
bast3800's Avatar
Member: 731596
Thanks Meter: 164
1-Load pm with 120 & 308 section removed
2-Super sd auth
3-Open the right windows and check "only RF & BB parametrs"
4-Than write pm
[IMG]http://i.*****.com/LtVCm.jpg[/IMG]
Old 03-11-2012, 03:03   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
3.5rev1.8
one click repair SD should end your problem
Old 03-12-2012, 08:22   #9 (permalink)
Member: 573120
Thanks Meter: 145
its still same . when i get mobile only camera on standby . but now its contact service . i do all possible things . now i think i have to purchase ATF BOX . I DONT KNOW WHERE I AM WRONG
Old 03-12-2012, 08:56   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. no reason but when all solution fails, then do this solution.
do this procedure carefully & step by step.
1. backup rpl: go > imei and security tab > imei rebuild > backup rpl
2. erase pm: go > pm tab > erase pm
3. reset npc data: go> imei and security tab> reset NPC data ( backup rpl before )
4. erase pm again: go > pm tab > erase pm
5. Write rpl from backup: go > imei and security tab > imei rebuild > restore imei
6. go pm tab > super sd auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again: go > pm tab > erase pm
8. recover CERT: go>imei and security tab> imei rebuild > recover cert
9. do full factory reset & enjoy.
phone will be come back from security test failed
its a last & 100% working solution from my point of view. have a good day.
br,
zuberchowdhry
Old 03-12-2012, 09:08   #11 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
im intended to purchase atf too bro, but not to repair security test failed.
dozens solutions provided in mxkey sections to solve this case.
BACK UP RPL, then u can do what u want with the phone.
the major solution is to write pm 1 & 309 to the phone.
dont afraid to try since u have the rpl back up.
u can erase flash before writing pm 1 & 309, or try rev 1.6, and many many others solutions. one failed, try other, one failed, try other again....
learning by doing bro.
good luck trying.
br
Old 03-12-2012, 09:13   #12 (permalink)
Cheater -Don't Deal with him-
Member: 1707492
Thanks Meter: 606
faking hit box notworking
Old 03-12-2012, 09:13   #13 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. you are right, learning by doing, one failed then try other again.
Old 03-12-2012, 09:16   #14 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
yeah, just working for smart people only bro.
no offense...
br
The Following User Says Thank You to specta For This Useful Post:
Old 03-12-2012, 10:11   #15 (permalink)
Member: 573120
Thanks Meter: 145
Atlast i do it myself
1. backup
2. repair sd
3. update splock
4. super sd auth
5. 1 & 309v pm
all done , any way thanx for all helping me here .........
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 05-11-2000 03:43
gsm service provider sidou Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-30-2000 11:09
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.32830 seconds with 10 queries
