02-11-2010, 18:49 | #1 (permalink) |
Crazy Poster Join Date: Apr 2004 Location: Spain Age: 46
Member: 60752 Status: Offline Thanks Meter: 1 | 5610d Contact Service Security_Test Failed I repaired SD, write full PM and repaired Simlock with Simlock RPL but phone is in contact service. Phone Type: RM-242 (Nokia 5610d-1) SW Version: V 07.12 28-05-08 RM-242 (c) Nokia Imei plain: 35895201950XXX-X Product Code: 0552249 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! "C:\Program Files\Nokia\Phoenix\Products\RM-242" folder created. Imei net: 358952019505817 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-11-2010, 18:57 | #2 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
http://forum.gsmhosting.com/vbb/show...36&postcount=1 | |
The Following 3 Users Say Thank You to Y.P.Y For This Useful Post: |
02-11-2010, 19:10 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 1.do SX-4 and write PM without [308] area in case after Superdongle repair , please use "SUPER SD Auth" 2.Check BB5 Secure Validation [MXKEY - INFO] !!! NEW magic button inside mxkey !!! this is have important info, where the real problem 3.do "Recover CERT" , if doesn't work Code: Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Just in case if Recovery via Server doesn't work....... need more file about CCC,HWC and VARIANT [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
The Following User Says Thank You to Andra For This Useful Post: |
02-15-2010, 06:56 | #5 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Quote:
Have u solved ur problem..........???????? i also hav same problem hav try to repair but not succed This method: 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here: i thing problem in my pm file...... if u hav good pm pls share for 5610d................. Rm-359 5610d -2b produce code : 0565932HP212V thank u....... | |
02-15-2010, 08:11 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
or see this link http://forum.gsmhosting.com/vbb/showthread.php?t=926798 | |
5610d contact service | patric | Nokia Base Band 5 ( BB-5 ) | 2 | 05-14-2010 09:54 |
5130c contect service.SECURITY_TEST failed | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-27-2010 14:25 |
3110 contact servis SECURITY_TEST failed! ???? | shivashakthi | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-15-2010 14:37 |
6300 contact service St_sleep_x_loop_test fail | temp_temp | Nokia Base Band 5 ( BB-5 ) | 3 | 06-11-2009 12:49 |
1650 contact service unlocking fail | tadpole | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 03-05-2009 10:56 |
