10-03-2011, 06:44 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 459869 Status: Offline Thanks Meter: 47 | 5800 finish flash but can't power on help. ## (SOLVED) Code: MXKEY Serial: [FT SCR2000 0] - C0807309 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: RM-356_52.0.007_prd.core.C00 [BB5,XSR 1.5] size: 108.08 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 10699746 CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0B100213C87500529F9C96CCF0E3EC278CAB87B2 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 36.750 s Processing PPM file: RM-356_52.0.007_prd.rofs2.V22 [BB5,XSR 1.5] size: 31.82 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 31.87 MB CMT FLASH,MuxOneNAND area [07180000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 29.546 s Processing PPM file: RM-356_52.0.007_C01_prd.rofs3.fpsx [BB5,XSR 1.5] size: 1.23 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 1.235 s Processing CNT file: RM-356_52.0.007_026_000_U01.uda.fpsx [BB5,XSR 1.5] size: 7.09 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 88.75 MB CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF] Flash programming ... Programming completed in 7.735 s Total time for flashing process(boot+erase+write) was 2 min 25.797 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
10-03-2011, 11:11 | #3 (permalink) |
Member: 459869 Status: Offline Thanks Meter: 47 | i'm using RJ45 FBUS flashing now: Code: MXKEY Serial: [FT SCR2000 0] - C0807309 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: UHCI:HUB:USB 1.10 (Full-speed) Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0B100213C87500529F9C96CCF0E3EC278CAB87B2 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 Processing MCU file: RM-356_52.0.007_prd.core.C00 [BB5,XSR 1.5] size: 108.08 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... erased in 0.907 s Prog.status for Asic CMT ... NOR: Success NAND: Success Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NOR: Success NAND: Success Programming completed in 9 min 26.187 s Processing PPM file: RM-356_52.0.007_prd.rofs2.V24 [BB5,XSR 1.5] size: 26.96 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 31.87 MB CMT FLASH,MuxOneNAND area [07180000-0915FFFF] erased in 0.266 s Prog.status for Asic CMT ... NOR: Success NAND: Success Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NOR: Success NAND: Success Programming completed in 2 min 26.063 s Processing PPM file: RM-356_52.0.007_C01_prd.rofs3.fpsx [BB5,XSR 1.5] size: 1.23 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] erased in 0.156 s Prog.status for Asic CMT ... NOR: Success NAND: Success Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NOR: Success NAND: Success Programming completed in 6.984 s Processing CNT file: RM-356_52.0.007_001_000_U02.uda.fpsx [BB5,XSR 1.5] size: 6.95 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 88.75 MB CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF] erased in 0.563 s Prog.status for Asic CMT ... NOR: Success NAND: Success Flash programming ... Prog.status for Asic CMT ... NOR: Success NAND: Success Programming completed in 37.687 s Total time for flashing process(boot+erase+write) was 12 min 49.875 s |
10-03-2011, 14:47 | #4 (permalink) |
Freak Poster Join Date: Aug 2005 Location: NO FACE NO NAME NO PLACE Age: 46
Member: 171973 Status: Offline Sonork: 100.1601062 Thanks Meter: 18 | phone goes to local mod or no when you use fbus cable ?? phone vibrate when you try to power on it or no??? br saeed azimi |
10-06-2011, 05:02 | #6 (permalink) |
Member: 459869 Status: Offline Thanks Meter: 47 | I get this error when during BB5 RAP3NAND erase user area: Code: CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0B100213C87500529F9C96CCF0E3EC278CAB87B2 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 Flash programming ... Error while programming [00] at 0x00000000, Result: 0000 |
10-06-2011, 05:16 | #7 (permalink) |
Member: 459869 Status: Offline Thanks Meter: 47 | 2nd time try BB5 RAP3NAND erase user area ok: Code: CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0B100213C87500529F9C96CCF0E3EC278CAB87B2 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 Flash programming ... Prog.status for Asic CMT ... NOR: Success NAND: Success Programming completed in 2.938 s |
10-06-2011, 06:55 | #8 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | try bb5 sw downgrade fix bro btw, what is the phone condition now? vibrate when power on? light of dial/no button turned on or what? or u can try using erase file. or u can try downgrade it to version 20.0.12 if u have back up. good luck bro br |
10-06-2011, 09:53 | #10 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - backup RPL: select RAP - full erase: get addr, don't mark safe erase. ERASE! - reflash ENO, restore imei, make repair simlock, make repair sd, reflash with latest firmware, |
10-08-2011, 10:23 | #11 (permalink) |
Member: 459869 Status: Offline Thanks Meter: 47 | After full erase i try restore imei & get this error message: Code: RPL: "C:\mobileEx\3.5\data\backup\BB5_35320503408834_BACK.rpl" Imei: 35320503408834 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0B100213C87500529F9C96CCF0E3EC278CAB87B2 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NOR: Success NAND: Success Phone type: RM-356 (Nokia 5800 XpressMusic) SW version: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia Imei plain: 35320503408834-2 Battery voltage: 4529 mV, current: 97 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
