02-22-2010, 11:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: sri lanka
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | 5800d-1 unlock problem ???.. My logs, Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1770000DC4820052ECD19D7864A36DFB9CE409EC ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.38.1 revision: 2.0 size: 0x3B40 Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Secondary Boot Media is not supported for the current interface. RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-356_358247038100538_BACKUP_SIM.RPL" Imei net: 358247038100538 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 4500000088401881 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 450FFF, DATA=450FFF sim lock update or nck calculate not succsess.. Pls,help me. Thanks. |
02-22-2010, 11:46 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
BB5 HASH Supported based : 38F312750F686F9FC9B1B3778774A195 9A28E119033B91D14D22838C86D0D53C 9DDBFCFE6E73CED7D8C6268C8EB85723 A5404AE83A594ECADEE532F0C236BFA6 BAF3A9C3DBFA8454937DB77F2B8852B1 CAEEBB65D3C48E6DC73B49DC5063A2EE E9EFF4BFAA5393217CA6B17755FC3E14 F2D76DFAFD66C7F195F278417DF05888 F682624FFB08F6D955DBE7D9C0485084 FCB5C510AF7F09F313D9BDE85A707CC0 | |
02-22-2010, 12:28 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Vietnam & China Age: 49
Member: 152057 Status: Offline Sonork: 100.1582385 Thanks Meter: 220 | 5800 SHOW is SL3, No box can't unlock at this time BR, MobileService |
The Following User Says Thank You to haiminhk15_sc For This Useful Post: |
02-22-2010, 12:31 | #6 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | this is supported now with unlock may be check your update used ufs to unlock that make full back up section |
02-23-2010, 04:32 | #7 (permalink) |
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | Thanks evry body..... I tried ufs interface and same problem ?.... Logs, Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1770000DC4820052ECD19D7864A36DFB9CE409EC ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.38.1 revision: 2.0 size: 0x3B40 Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Secondary Boot Media is not supported for the current interface. Imei net: 3582470381xxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 4500000088401881 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 450FFF, DATA=450FFF Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V ICPR72_09w20.13 29-09-09 RM-356 (c) Nokia ERROR: Missing SP BLOCK or PM corrupted Thanks to evry one help to me...... |
02-23-2010, 04:55 | #8 (permalink) | |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | @re Quote:
Any 1 here????/ Regard: GSM_3GN | |
02-23-2010, 04:56 | #9 (permalink) |
Freak Poster Join Date: Jun 2007 Location: pakistan Age: 40
Member: 522050 Status: Offline Thanks Meter: 62 | ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 your hash is not supported BB5 HASH Supported based : 38F312750F686F9FC9B1B3778774A195 9A28E119033B91D14D22838C86D0D53C 9DDBFCFE6E73CED7D8C6268C8EB85723 A5404AE83A594ECADEE532F0C236BFA6 BAF3A9C3DBFA8454937DB77F2B8852B1 CAEEBB65D3C48E6DC73B49DC5063A2EE E9EFF4BFAA5393217CA6B17755FC3E14 F2D76DFAFD66C7F195F278417DF05888 F682624FFB08F6D955DBE7D9C0485084 FCB5C510AF7F09F313D9BDE85A707CC0 |
02-23-2010, 05:23 | #10 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1170910 Status: Offline Thanks Meter: 76 | select proper Flash Update Directory file Go to Config -> Select Flash Update Directory -> and select 8.30.12.34xxx click OK -> Apply Ok -> Disconnect interface and restart mobile ex. 100% your problem will be solved. regards |
01-26-2011, 05:18 | #11 (permalink) |
Freak Poster Join Date: Jan 2010 Location: cavite
Member: 1215525 Status: Offline Thanks Meter: 25 | elect proper Flash Update Directory file Go to Config -> Select Flash Update Directory -> and select 8.30.12.34xxx click OK -> Apply Ok -> Disconnect interface and restart mobile ex. 100% your problem will be solved. how????????????? |
01-26-2011, 05:41 | #12 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Using ATF as interface it'll supported for booting and flashing' But not for unlocking because it's SL3. If someone thinks to calculate using GPU that's different |
5800d-1 unlock problem!!! | jr astigin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-24-2010 06:25 |
5800d-1 unlock problem v.3.3 and 3.2 | unchiu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 01-17-2010 22:33 |
Nokia 5800d-1 light problem | maruti | Nokia Base Band 5 ( BB-5 ) | 3 | 07-17-2009 05:34 |
5800d-1 UnLocK dOne by ub | kalicutez | Universalbox | 0 | 04-21-2009 09:12 |
