Old 04-01-2010, 04:25   #1 (permalink)
Member: 507832
Thanks Meter: 78
Thumbs up 3110c SECURITY_TEST failed help
hi
si plz help me 3110 c contat srievs repair sd ok supper sd auth ok but same problem write ncp rpl but same problem plz help me
anguage Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 351939032312278
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 04-01-2010, 04:27   #2 (permalink)
Member: 752215
Thanks Meter: 23
sd auth then
write pm 1 and 309
Old 04-01-2010, 04:36   #3 (permalink)
Member: 367030
Thanks Meter: 16
make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
Old 04-01-2010, 04:46   #4 (permalink)
Member: 507832
Thanks Meter: 78
same problem br any one suln
Old 04-01-2010, 05:12   #5 (permalink)
Member: 278546
Thanks Meter: 145
Originally Posted by thethi View Post
hi
anguage pack:
- not available.
simlock seems to be valid
superdongle_key seems to be valid
cmla_key seems to be valid
wmdrm_pd seems to be valid
simlock_test passed
security_test failed!
imei net: 351939032312278
version: simlock server version 63
provider: nokia test, country: finland
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block 1: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 2: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 3: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 4: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 5: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 6: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 7: 1=open 2=open 3=open 4=open 5=open, data=ffffff
give me rpl, read rpl from mx key select only rap.
Old 04-01-2010, 07:13   #6 (permalink)
doller's Avatar
Member: 524817
Thanks Meter: 206
same problem for me
here is my rap rpl how to solve it
Old 04-01-2010, 08:10   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
here is your RPL include PM data to SX-4 Auth
3110_35678902156108
please post report here with details log
br,
Old 04-01-2010, 10:03   #8 (permalink)
Member: 600467
Thanks Meter: 27
try this procedure.....
-open mxkey dongel
-then go to service
-click imei & security
-click imei rebuild
-back up the rpl..
-repair SD
-SUPER SD AUTH
-click load file then write pm
-then go to click imei & security then tick repair simlock then repair Splock
Old 04-01-2010, 10:13   #9 (permalink)
doller's Avatar
Member: 524817
Thanks Meter: 206
3110_35678902156108
br,
try this solution but not working
log
Using device: J.A.F, FW ver: 01.B4
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2A200110F15A7C561F52177479CF6D5FFFC0A1B5
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Original Imei: 35678902156108
Original Product code: 0550573
Bluetooth ID: 0022FC1FDF8B
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35678902156108-7
Product Code: 0514959
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 356789021561087
Counter: 0/3, 0/10
Old 04-01-2010, 10:15   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
are your already do SX-4 and write PM file ?
log please .
br,
Old 04-01-2010, 10:28   #11 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
get ur rpl from here
ps before doing any opration make backup of rpl & pm
Old 04-01-2010, 10:37   #12 (permalink)
SANWER's Avatar
Member: 581945
Sonork: 100.1601426
Thanks Meter: 62
add my yahoo id in your yahoo massenger and contact me 100% solution id-<font color="Red"><font size="4">...</font></font> or +8801712754121
Old 04-01-2010, 10:38   #13 (permalink)
SANWER's Avatar
Member: 581945
Sonork: 100.1601426
Thanks Meter: 62
(((((((((((((((((((((((((((((((((((((((((((((((((( (((([email protected]))))))))))))))))))))))))))) ))))))))))))))))))))))))))
Old 04-01-2010, 10:44   #14 (permalink)
tsavofather's Avatar
Member: 326603
Thanks Meter: 25
-open mxkey dongel
-then go to service
-click imei rebuild
-back up the rpl..
-repair SD recover sertificates
-SUPER SD AUTH
full factory settings
tested in 50 phones its working
The Following User Says Thank You to tsavofather For This Useful Post:
Old 04-02-2010, 04:56   #15 (permalink)
Member: 278546
Thanks Meter: 145
write this rpl and post me result
3110 SECURITY_TEST failed!?? help me...? (ANSWERED) arfanskg MXKEY Nokia Flasher and Unlocker (by Alim Hape) 21 02-27-2013 22:09
3110C Security_test failed done with SuperSX4 auth server upadate bireun MXKEY Nokia Flasher and Unlocker (by Alim Hape) 20 09-09-2010 13:36
e71 x SECURITY_TEST failed! help me[SOLVED] goverdhan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-08-2010 13:53
help me for 3110c SECURITY_TEST failed! krishnaaruna MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-10-2010 12:56
Nokia 3110c (CS) SECURITY_TEST failed![SOLVED] jodhpur_raj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 02-09-2010 11:24
Page generated in 0.25452 seconds with 10 queries
