Old 02-18-2010, 00:43   #1 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Question Oh No !!! 2323c Dead After Reset DATA1
I Can't Believe it !!!!!
MX-KEY Team Help Me.......
Nokia 2323C Dead After Reset DATA1, Then Reset All..
Then I Tried to Rebuild IMEI, Restore IMEI, Again tried to Full Flash But i can't it..
plz any body help me...
Thanks
Hossne Mamun
The Following User Says Thank You to hossnemamun For This Useful Post:
Old 02-18-2010, 02:09   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
try to flash with ufs interface.
br
Old 02-18-2010, 02:50   #3 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
first flash with jaf dont make unlock
second make imei or unlock with mxkey
and thats it .
Old 02-18-2010, 02:55   #4 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
ufs must be used for this situation .what is the problem of your phone why you reset data 1 are you try to changes imei .
Old 02-18-2010, 03:27   #5 (permalink)
Member: 139167
Thanks Meter: 13
Data1 is imei and lock data from flash part, you can repair it using unlock procedure.
Old 02-18-2010, 03:39   #6 (permalink)
Member: 1220048
Sonork: dragon23456
Thanks Meter: 5
sir you styring to sim lock....
Old 06-24-2010, 14:20   #7 (permalink)
Member: 1331621
Hi guys , i would like to format my nokia 2323 classic . How to do it ? Thank
you .
Old 06-24-2010, 14:34   #8 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
you .
Do you mean erase flash or format user area??
to erase go to Flash->Advance and you will find there.
To format file system go to Service->Action at the bottom right corner, there is Format file system, press scan and if the drive name comes, select it and press Format System.
Br'
curvenger
Old 06-24-2010, 14:57   #9 (permalink)
Member: 1331621
I would like to clean up everything because when i try to write a message
take this ( Message storage memory not ready ). Maybe to be full of
messages . What to do ? Thank in advance .
Vk207i dead after Reset settings Blartiartfast Infinity-Box 1 12-11-2006 00:59
Zonda 1880 dead after reset settings. desbloqueocelgd Infinity-Box 1 10-01-2006 20:45
VK500 No sub LCD after reset ! Neep help . BMobile Infinity-Box 5 05-13-2006 10:37
samsung E700 dead after reset MMI Mounir Twisterflasher 8 10-21-2004 07:36
GSMLAB Plz help T68 dead after reset GDFS banKa Sony Ericsson 1 09-16-2002 05:58
Page generated in 0.20518 seconds with 9 queries
