6120c unlock problem .need help argently (ANSWERED) Imei net: 359342039163830 Version: SIMLOCK SERVER Provider: Telstra Mobile Comms, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050100058056920 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 50501F, DATA=50501F BLOCK 2: 1=LOCKED (MCC+MNC): 50501F, DATA=50501F Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.10 15-07-09 RM-243 (c) Nokia ApeCoreSw: 07.10 SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Custom loader not available for this ID ! whats fault ? |
check info Phone Type: RM-243 (Nokia 6120) SW Version: V 07.10 15-07-09 RM-243 (c) Nokia Imei plain: 35934203916383-0 Product Code: 0567116 ApeCoreSw: 07.10 ApeVariant: rofs_version_inforofx_version_info ApeTest: rm243_ENO_A_2009wk15v0.100 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed Imei net: 359342039163830 Version: SIMLOCK SERVER Provider: Telstra Mobile Comms, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050100058056920 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 50501F, DATA=50501F BLOCK 2: 1=LOCKED (MCC+MNC): 50501F, DATA=50501F bus check info Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0D50000F118C00524B294C1D4EAE79C733D8796F ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40 Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! |
Calculate Nck code and simply hit that code.....NO risk....safe method |
just clean fbus point and try several time or use cyclone box as it has latest flash loaders |
1st make RPL and pm backup else it may be a big trouble |
best method just use usb and chk bus than update simlock because 6120c can be unlocked only by usb interface tested by me good luck |
hey man......use jaf.......... change cable......use 7 pin cable.......do with out display..... |
Bro what interface you use change interface and just try again fhone is unlocked 100% |
try with hwk all will unlock with out internet you can unlock any SL2 nokia mobile. |
1. Write back PM backup, it should take backup automatically 2. Reunlock 3. Buy proper tool |
are you sure it is sl3 .hmmmmmm this mobile i have only unlock this version this is what we could 9DDB has but this is not sl3 this is SL2 unlock with hwk it is very safe .your problem solve mx key is not working sometime because used server to unlock so hwk is not required this for server. regards: long lee |
